This way seems much more sensible, and I calculate a decent net profit, if one was to sell off their EFI parts as spares on Ebay. I've been interested in accumulating the correct parts to make this conversion, but having a difficult time identifying and sourcing the specific components I'd need to convert my 2012 NA export C5.
Doesn't the stator also need to be changed so as to provide the pickup for ignition timing? Would you know the stator part number for this conversion? Would you know the part number for the rotor? The TCI? The harness I can manage.
Could you post or message the wiring diagram from the India market machine?
Is there any way to adapt these parts from a 350 engine? Those seem much easier to find and the pictures look the same to my eye. Which dimensions are different?
Here are the RE parts list I use for the 500 EFI to Carburetor conversions
570889/B -VB51 UCD33 carb
570888/A -VB51 TCI Unit multi curve (some EFI model already may have this installed)
582601/A -VB51 TPS add on lead (harness to connect the carburetor TPS to TCI unit)
570896/A -VB51 Accelerator cable (Throttle Cable)
570886/B -VB51 Carburetor manifold 570886/B (connects carburetor to cylinder head)
592237/A -Rotor assembly (This replaces the EFI rotor and is from the Carburetor Classic 350 UCE model has only 1 trigger tooth to help the TCI identify TDC, looks somewhat similar to the rotor from the earlier AVL engines. You should be able to reuse existing EFI stator. The combined rotor and stator assembly part number is 570866/A).
888311 -Wiring harness kit (from the Classic 350 carburetor model)
RAC00156/A -Ignition coil main (may not be required if the ignition coil connectors of the EFI model are the same)
147096/A -Auxillary ignition coil (may not be required if the ignition coil connectors of the EFI model are the same)
594002/A -Cover fuel tap (Pentagon shaped plate that replaces fuel pump assembly for a fuel tap to be fitted)
584668/A -VB51 fuel tap assembly (UCE 500cc fuel tap)
573140/A -NR61 air filter pipe outlet (Rubber connector to connect carburetor to air filter box)
592173/C -Ammeter (Ammeter from Classic 350)
560195/C -RH switch (Right Hand Handle bar switch carb model, allows the headlight to be switched on and off)
There are a few different ways of doing the wiring, you could also use parts from the 500cc AVL Electra X like the wiring harness, TCI, ignition coil and ammeter. The Electra X TCI can only fire only 1 spark plug. There is also a dual spark output ignition coil available too (591837/A used on some EFI models).
People have tried the 350 TCI unit and that causes the ignition timing to be advanced, its better to stick to a 500cc TCI unit. Again there are many different ways of doing this conversion.
