Morning all,
I've just moved across from the Hitchcocks forum as I felt I may have a bit more freedom to discuss products and companies etc over here?
I've got a 2006 Electra that I've had for a year now and done a few hundred miles on, recently took part in the Hull Distinguished Gentleman's Ride, but other than that not done a lot with. She's woefully underpowered, a bit tired, and leaks like a leaky thing trying really hard in a leak-off contest.
Just under 10k miles and just run out of MOT.
So with that, and having read about imminent crank failure etc etc, I've decided to take her off the road and give it a full spruce up with a view to never actually doing all that many road miles on it again.
The plan was to make it as powerful and strong as possible, and get it entered in some races. Having done a bit more digging into racing viability, I'm thinking now the plan is to get it stripped down to as little as it needs for a basic daytime MOT, and do all the necessary engine work to eek out some ponies and get it entered into things like Malle Mile, Dirt Diggers, beach races etc, for a laugh if nothing else. I ride trials currently and have had bigger and faster road bikes in the past, I'm hoping the little Enfield can continue to scratch the old school cool itch for a few years yet!
How it looked when I brought it home:
https://ibb.co/cc7g22pHow it sat at Hull DGR:
https://ibb.co/SRct2CQhttps://ibb.co/1Q54WP2How it looks now, braced bars fitted and partially stripped:
https://ibb.co/sP0QD9Jhttps://ibb.co/vz2YMvnI'm thinking:
- Smallest battery possible if not battery-less
- Trials kit, ish. 21" front wheel, knobblies, bash plate etc.
- No indicators. Possibly even remove the casquette and fit a number board. Leaving only brake light and horn, need to look into MOT and construction & use etc etc...yawn
- Lanyard cut-off and relocate ignition switch
- Sprag clutch removal and either blank it or source a humpless inner primary. It's borked anyway and I've already removed the rest of the starter stuff.
- Better crank...research still being done.
- Port work.
- Cams from the redditch Bullet - that's a thing isn't it?
- Full clutter removal, centre stand, clutch switch, sidestand switch, decompressor, absolutely anything not needed shall be removed.
- Big bore if it's worth doing?
Lots of research still to do, lots of head scratching and late nights, but looking forward to getting cracked on.
Shout out to Adrian for all his help already
Thanks
