Not a successful day. Installed the new Price "R" cams. Had to make a little bit of clearance on the case, installed fine and set the lash. Double checked the timing
Fired it up, started a lot easier than the Indian cams. Nasty clack, clack, clack coming from the head. (more noise than usual)
Whipped the timing cover off again. Double checked and re-set everything, checked timing again. Bolted back together. Fired it up again.
Same again. **Clack Clack Clack**
Popped the rocker covers off. Slowly kicked it over with no spark plug. I could hear the "clack" coming from one of the valves.
Removed the intake valve rocker box and push rod as a process of elimination. Figured out it's the exhaust valve. Makes a nasty clack when it closes. Even when just kicking it over with no plug. With both inlet and exhaust rockers and pushrods removed. No noise. So it's the exhaust valve.
The head is original and has got 50,000+ miles on it. So I'm guessing its due for a rebuild. The exhaust valve has always made a bit of racket. But the new cams being a different profile and slightly higher lift might of amplified the issue, or may even made the valve sticky if they are being lifted past their "wear bedding"?
I'd guessing the guide is also worn and sucks oil in because it tends to make plugs look a bit wet/burnt oil at times. Also the top end socket of the push rod is loose. Has a bit of slop and spins around.
Ran another compression test. It's down from 175psi to 130psi.
So something isn't healthy up there, looks like I'll be rebuilding the head sooner rather than later.
**sigh**
At the moment I'm trying to remove the head without force. It's got a lot of glue holding it on!
I try do things in steps so when it comes to tuning it's not a huge change. But looks like it's getting the Hitchcocks Oversize valves now and some port tuning.
Luckily the GT535 is in good shape and I have it to ride.
