Materials arrived to make velocity stacks.
Once again like my Bullet airbox. The stack is made out of a 304 stainless steel donut. So the radius of the bellmouth is the radius of the 1 3/4 pipe.
I've been tacking them together to trial different lengths. Then once happy I'll fully weld one and dress it up.
First test was with the existing Velocity stack. But modified so its a 2 piece setup with a carburetor boot joining the two. For easier changes. This measure 100mm from the airbox wall.
On the test ride it did everything that Taurim had reported with his with the longer stack. Smoothed out the transition up to 3500rpm when these cams come on song. Instead of a abrupt hit. Felt like it gained a little bottom end.
Although the standard boot from the airbox to the throttle body isn't quite straight and has a bit of a off center bend to it.
You can see in the next image what I'm talking about with the exposed edge of the throttle body. So I decided to improve this.
A rough diagram showing how I aim to improve the boot from the airbox to the throttle body and also how to mount the velocity stack. A 3 clamp setup. One on the throttle body, one on the airbox and one securing the pipe for the velocity stack.
Can see the end result here. Its just a silicone hose reducer. 51mmx44.5mm or 2" x 1-3/4". Worked a treat. Secures the first section of the stack and the tract is aligned the best it can be. The Carburetor boot in the foreground for the 2 piece velocity stack setup.
Pictured above is a stack length 90mm from the airbox wall. 10mm shorter from the longest length. Which brought back the known 3500rpm hit these cams do. Which feels no different to the original 70mm stack length I had in there.
Next I'll try 95mm. See if that gets it a happy medium.
I've been making phone calls on various different Dyno tuners. All are over a 4hr drive away for me so I decided to order a Power Commander Auto Tuner and tackle the task myself.
My local dyno tuner who is semi retired and is no longer running his Dyno due to health issues swears by these devices and recommends it for a DIY guy like myself.
Also he'll give me the run down and tips and tricks on how to get the best out of it since he's not running the Dyno.
I have the gist of it, but always open to learn more. Should arrive in a week or so then I can really start testing different stack lengths.
But for now I just wanted to get the mounting of it all a better, sturdier setup.
Cheers
Ben
