Author Topic: Adjusting the heel/toe shifter to allow toe only shifts?  (Read 3017 times)
Dexter
  • British Columbia, Canada
Has anyone who already has a Meteor attempted rotating the shifter assembly on the gear shaft to a different position (rotating clockwise) to see if you can make it work for the toe better on the upshifts, instead of using the heel?
Looking at it, it appears that would move the toe part up higher to allow upshifts easily with the toe. With proper m/c boots on, it is too difficult to bend the ankle enough to achieve toe upshifts. and it looks like only the one part, where the linkage meets the gear shaft, needs to be moved.
Past rides:
1966 Honda 65 Sport
1967 Honda CB160
1973 Honda CB750
1982 Honda V45 Magna - the most uncomfortable bike I ever did a cross country tour on!
1983 Honda CB1000
1995 Honda ST1100 - sold 2015 after 175,000 km
1996 Honda ST1100
Current ride:
2021 Royal Enfield Stellar Blue Meteor 350
Reply #1 on: July 31, 2021, 11:55:02 pm
         Get a toe-only gear shift lever?
GSS
Reply #2 on: August 01, 2021, 07:14:04 am
It will be a simple 5 minute job to remove the bolt and rotate it up by a notch…..you will need to remove a cotter pin and disconnect the linkage otherwise there isn’t enough room to slip it off the gear shaft.
You can’t use an old fashioned toe shifter as the footrest is too far forward and the engine case is bulbous. It would be easy enough to cut off the heel extension off this one. Thanks.
2019 Himalayan Snow
Previous REs:
Dexter
Reply #3 on: August 01, 2021, 07:16:18 am
AFAIK, RE does not offer such an accessory for this bike.
Past rides:
1966 Honda 65 Sport
1967 Honda CB160
1973 Honda CB750
1983 Honda CB1000
1996 Honda ST1100
Current ride:
Dexter
Reply #4 on: August 01, 2021, 07:24:37 am
I do plan to try that, but I was hoping someone else might have found this to be a solution already. The only fly in the ointment could be if that splined shaft has a "keyway" that only allows one mounting position. Haven't inspected it closely enough yet, as I just got the bike on Saturday. One of the first half dozen Meteors now on the roads of the Vancouver area.
I have to say, the bike shifts soooooo smoothly, that I couldn't tell if I had actually made the change until the clutch went back out. Shifting with the heel seems not quite as sensitive on the foot, as the toe shift is.
I was quite impressed with how smooth the transmission shifts are though, compared to all the Hondas I have ridden.
Past rides:
1966 Honda 65 Sport
1967 Honda CB160
1973 Honda CB750
1983 Honda CB1000
1996 Honda ST1100
Current ride:
Reply #5 on: August 01, 2021, 11:47:41 am
        I should have known better than to comment on something I've not looked at live and in living color.  I didn't realize there was a problem with just putting a normal lever on it.
         That said, I really do like the look of the Meteor and the fit and finish (AND the out-on-road comments of reviewers who are fair to what the bike is) seems excellent from the reviews I've read and seen. I'd like one in Babylon Taxi black and yellow please and it pisses me off no end that I'm 83 years old  :) :)
Carlsberg Wordsworth
Reply #6 on: August 01, 2021, 07:22:53 pm
Hooray, congrats. Hope you managed to get some miles in today :)
Dexter
Reply #7 on: August 01, 2021, 08:25:23 pm
Thanks. Managed to put about 50 km on yesterday getting it back home via a slight "detour" route. Sprinkling rain here and there which kept it short. Over six weeks of solid sunshine (drought) weather here and it chooses to rain on the day the bike is ready!
Going to spend today fitting the RE windshield which I had to order from Hitchcocks, as RE North America said they do not and will not have it in stock, as it hasn't met DOT standards for this side of the pond. Probably RE hasn't applied for that yet, or paid the piper to get it.
Past rides:
1966 Honda 65 Sport
1967 Honda CB160
1973 Honda CB750
1983 Honda CB1000
1996 Honda ST1100
Current ride:
GSS
Reply #8 on: August 01, 2021, 10:55:58 pm
Tried rotating it one notch today but the linkage gets too close to the footpeg mount and hits it during upshifting. Went back to the stock position for now. This may or may not be an issue with other bikes. Might have to figure out a slightly longer and/or adjustable linkage similar to the 410 and 650 linkages to raise the pedal without repositioning it at the shaft.
2019 Himalayan Snow
Previous REs:
Dexter
Reply #9 on: August 02, 2021, 07:51:26 am
Yes, I tried it today too and had the same result. Dang! It doesn't need much more clearance to do it either. I'm thinking of going to a metal shop with that offending piece of the linkage and getting one made to the same dimensions, but with a small U shaped bend in the rod right at that point where it contacts the footage mount.. Maybe a winter project.
Moving it up that one spline did make the toe shift quite doable.
Let me know if you come up with a better idea or easier solution.  Cheers!
P.S. Where are you located, as I noted you have a Supernova Blue, but can't tell from your avatar if it has the windshield? Supposedly not available to the North American market, unless you get it from Hitchcocks, as I did for my Stellar Blue.
« Last Edit: August 02, 2021, 07:56:48 am by Dexter »
Past rides:
1966 Honda 65 Sport
1967 Honda CB160
1973 Honda CB750
1983 Honda CB1000
1996 Honda ST1100
Current ride:
Reply #10 on: August 02, 2021, 08:14:53 pm
I think that's GSS's teal classic in his avatar  ;)
GSS
Reply #11 on: August 03, 2021, 04:29:09 am
I am in the tropical climes of Minnesota  :)
No windshield on the Supernova…..without the windshield all you get is the polished edge on the spokes of the wheel. It doesn’t even have the painted mudguards that you get with the stellar….just black.
That is indeed my chrome-teal Classic 500 with SB/GHG engine mods and a ton of extras that I am unfortunately parting with to make room in my garage for the meteor  :(
« Last Edit: August 03, 2021, 04:34:33 am by GSS »
2019 Himalayan Snow
Previous REs:
Dexter
Reply #12 on: August 20, 2021, 10:36:47 pm
Just to update this thread:
Hitchcock's has a number of accessory projects in the works for the Meteor and I was recently informed by them that a replacement linkage is fairly high on their list of items to offer, as soon as possible and to watch their accessory pages for the Meteor.
Good news for those wishing to ditch the heel shift.
Past rides:
1966 Honda 65 Sport
1967 Honda CB160
1973 Honda CB750
1983 Honda CB1000
1996 Honda ST1100
Current ride:
mickyd3d
Reply #13 on: September 25, 2022, 06:17:44 pm
My solution to the heel-toe shifter problem was simply to cut off the heel part.
I did try to get used to it but I just didn't like it.
I am now enjoying my rides 100%.
I did make one more modification to bring the toe shifter up slightly.
I am absolutely pleased with the way it is now.
This is an old thread so if anyone still interested I will post details of what I did?
Electra Steve
  • Birdwood, South Australia
Reply #14 on: September 27, 2022, 06:25:18 am
I made an adjustable linkage to let me set the lever for toe change, then promptly broke my toe so now I use the heel and toe and I am now used to it and like it.
Previous rides. Many Hondas
BMW R60/2
Norton 99
NSU Supermax
2007 RE Electra
now 2021 Stellar
