A lot of the GT 535’s came from the factory with pre-detonation issues below 3,000 RPMs. Tom of ACE Motors who is well known for building the ACE Fireball iron barrel 500. He also has designed and manufactures his own ACE Performance branded billet aluminum performance heads and performance cam. Several years ago when he bought his first GT 535 to use as his test mule, he noted that the 535 UCE engines were prone to pre-detonation below 3,000 RPMs and during this time, was recommending that the GT 535 should not be ridden below 3,000 where the engine experiences most of its pre-detonation issues.
Do a search on this forum for “Squash Modification”. This is what Tom and a few others came up with as the proper engine barrel modification to not only eliminate engine pre-detonation but also raise the engine compression. Its a fairly simple and low cost modification that will increase performance.
I’v owned my ‘14 GT 535 since brand new from the dealer. Iv got 13,500 + miles on it now. 100% of my ridding has been between 3,000 - 4,000 RPMs. I can hit the freeway at 65mph and still be under 4,000 RPMs.
In my opinion, your lugging the engine when ridding around below 3,000 RPM. Especially if you live in a hilly area. Lugging an engine under a load is not good for the engine, unless the engine is designed to operate at low RPMs while under a load. The 535 UCE engine is not designed for low RPM lugging around.
Every type of ridding I do, in my subdivision with a 20mph speed limit, rolling quite 2 lane back roads, freeway ridding at 65mph can all be very easily achieved with ridding between 3,000 - 4,000 RPMs. With my experience, ridding above 4,000 RPM’s, the engine vibrations are much more pronounced and get worse and worse the higher you go above 4,000 RPM’s. Between 3,000 - 4,000 RPM’s, my GT 535 is fairly smooth.
At 31 mph (50 kph) Im in 2nd gear with the RPM’s around 3,500 +- 100 RPMs. On the freeway at 65 mph (104 kph) Im in 5th with the RPMs right around 3,800. The bike is quite happy. Im not lugging the engine and Im not forcing a galloping horse to run faster.
