Author Topic: Chain tensioner Bolt leaks  (Read 2584 times)
ofi
on: July 30, 2020, 04:56:09 pm
Hello,
my name ist Oliver and I live in Germany. Please excuse my bad English.
I bought a Bullet Classic from 2009 this Sunday and I am very happy with it.
Unfortunately, oil drips from a screw that I think is the chain tensioner.
Can I just unscrew and seal the screw without the inside falling apart?
Thank for your help.
Haggis
Reply #1 on: July 30, 2020, 08:00:19 pm
Looks like someone has changed the automatic adjuster for a manual version?
When you take out the centre bolt there is a spring that pushes up a plunger to tension the primary chain.
« Last Edit: July 30, 2020, 08:05:30 pm by Haggis »
Off route, recalculate?
johno
  • 2012 B5 on the original Portland Dorset UK
Reply #2 on: July 30, 2020, 08:10:12 pm
The 2009 should have the auto chain adjuster, that bolt should be tight to set the slipper against the chain, this would stop the leak as well.
here is a new one.
https://accessories.hitchcocksmotorcycles.com/20011?qty=1&continue_url=https%3A%2F%2Fwww.hitchcocksmotorcycles.com%2Fpartsbook-pages%2F2127
2012 B5 Bullet
 K&N, sport muffler, 18tooth fr sprocket, Avon style fairing, 1958 pattern British army haversacks. Mitas tyres DiD chain. Carberry plate.
ofi
Reply #3 on: July 30, 2020, 08:47:11 pm
Thank you for your answers.
I have ordered a new tensioner.
According to the pictures, I can change the tensioner without removing the cover of the primary chain.
The correct tension will be set automatically with the new one.
gizzo
  • purple people
Reply #4 on: July 30, 2020, 09:29:24 pm
Yes. But make sure you take the cap and spring out of the new tensioner and retract the extendable pin (release the ratchet mechanism or you won't be able to do this) before you install it. Once the tensioner is installed, then fit the spring and the cap. Otherwise you'll be trying to fit a fully extended tensioner.
« Last Edit: July 30, 2020, 09:32:42 pm by gizzo »
simon from south Australia
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
Ove
Reply #5 on: July 30, 2020, 10:27:13 pm
That's an odd thing to remove. Could there be a reason it was taken off?
Haggis
Reply #6 on: July 30, 2020, 10:44:21 pm
Maybe took the bolt out and lost the spring?
When you refit the new one the word "Pricol" should be on the inside, towards the engine.
You should not have the ratchet mechanism facing out.
The one in my second photo is in the wrong way round.
This is the correct way round,
gizzo
  • purple people
Reply #7 on: July 31, 2020, 12:12:40 am
Does it make a difference? Only asking because it looks symmetrical and that it'll fit either way but in my GT the frame tube clearance only lets it fit one way.
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
Haggis
Reply #8 on: July 31, 2020, 12:38:19 am
Not symmetrical,  the plunger mechanism is offset to one side. If you fit it with the writing outwards the plunger pushes on the edge of the tensioner blade. This gives uneven pressure on the blade as you can see by the wear marks. If you fit it the other way it pushes on the centre of the tensioner blade.
« Last Edit: July 31, 2020, 12:41:15 am by Haggis »
gizzo
  • purple people
Reply #9 on: July 31, 2020, 01:14:03 am
I see. Thanks.
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
Frogman8
Reply #10 on: July 31, 2020, 06:54:04 am
Haggis
Extremely detailed and useful pictures. Thanks for archiving and levelling them for ease of understanding. This is what makes this such a great place.
2011 G5: The 'new' 'Toofan' Mail. Thunderous name.. pedestrian pace
2008 Iron Barrel: Sold in a moment of madness
2001 Triumph Legend 900
2013 Kawasaki KLX 250, will ride someday
1991 Honda Nighthawk: Sold...Incredibly boring
1982 Honda Magna V45: Hmm
1988 Jawa/ Yezdi 350 twin: Many miles, more stor
Arschloch
  • ...all is lost
Reply #11 on: July 31, 2020, 08:41:58 am
There have been cases of snapped primary chains and exploded engine housings. People on Enfield forums started replacing the primary chains and building own chain tentioners to avoid having a fatal engine failure. While rebuilding my engine I realized that between the crank drive side bearing and the drive sprocket there is a spacer, if anyone misses to assemble that (factory, workshop) than the sprocket and clutch basket are not alligned properly. This is more likely to snap the chain than anything else IMO.
Haggis
Reply #12 on: July 31, 2020, 09:28:41 am
Caught one my primary chains just in time.
Guaire
Reply #13 on: July 31, 2020, 02:56:59 pm
Excellent!
Ove
Reply #14 on: July 31, 2020, 03:52:18 pm
Thanks for the explanations and photos. Excellent. What sort of mileage was on the primary up to this point?
