Yea, maybe I should clarify my point...…….I blew up my gear box, basically had shards in there.
It's completely rebuilt, and somewhere along the way, I lost the ball. without it, the clutch rod doesn't even extend for the clutch lever to push it. I added 1 ball, and I didn't get enough throw. So I added the second, and that did the trick. There is a thread on this in the forum here, ACE even weighed in.
So I had a fundamental rebuild which is an obvious change.
It is weird that everything worked, and now it doesn't, and there are no changes. Like Paul says, it's just 2 rods and a ball, nothing to go wrong. I supposed these things can wear over time of course, but it doesn't seem like there are a lot of miles on the bike.
Nevertheless, if throw is the issue, I'd be tempted to add one to see if that does the trick. If it does, I guess a) you could leave it in there like I did, but I don't know the long term consequences of that, so best to get advice, or b) you know something is wrong there and maybe take it apart and see what's up.
