Author Topic: Successful carb settings redeux  (Read 33068 times)
Bilgemaster
  • Just some guy
  • Global Moderator
Reply #30 on: August 16, 2019, 03:08:38 am
This is a potentially very useful thread. Parsed by carb type it might one day make for a handy reference database of best proven practices. Shame the old thread got lost in the shuffle.
Just as a sort of baseline, I wonder if someone could provide the stock Mikcarb VM28 and other carbs' factory setup(s) through the years with the stock exhausts, both with and before the Air Pulse Valve, "Catalytic" Tube, and so forth were added.
Reply #31 on: August 16, 2019, 05:32:26 pm
Needle jet is way too rich.
Try P4 or P6 needle jet.
           Which person and which carb is this a Reply to? ???
Adrian II
Reply #32 on: August 17, 2019, 03:23:15 pm
This one, tooseevee!
Heloego, Your post sounds the closest to my bike so maybe you can help me here? Iron barrel 2006 Classic with standard muffler. Recently bought Mikuni VM32 and is now jetted as follows.
Pilot 30
Main 180
Needle 6DP17
Needle jet Q6
Clip in middle slot
Slide is 3 (standard)
It has a POD filter
Runs ok but I feel it could go better. I don't want a loud muffler hence the stock one. Recommend a free flow muffler that is not too loud if you can. I have experimented with a main from 150 to 250 and a pilot from 25 to 35. The only time I got it running any good at all was when I replaced the recommended 6F05 needle jet with the 6DP17 which was on the carby as delivered. I started a post on O2 gauges which I have temporarily fitted but no matter what jetting I use it tells me it is too rich even though the plug looks ok.
Reply #33 on: August 17, 2019, 04:00:08 pm
      Ah! Danka.
      If VM not TM then Ignore.
      Sleep.
« Last Edit: August 17, 2019, 04:03:58 pm by tooseevee »
Adrian II
Reply #34 on: August 18, 2019, 12:52:14 pm
Still good carbs, though. The TMs are taller, which can occasionally lead to under-tank clearance issues, especially with the accelerator-pump versions. This one might have gone a wee bit too big.
Reply #35 on: August 18, 2019, 09:27:33 pm
           I wasn't dissing VMs.
            I commented that only because a TM is what I have on the bike so I is disinnerested in VMs.
Adrian II
Reply #36 on: August 19, 2019, 02:44:51 pm
No dissing was read into your post, tooseevee!  :) I had good results with a TM36-31 pumper carb on my old Electra-X (still got that carb!) as well as a VM32 on an old BSA of mine years ago.
Ace did a lot of work with the TM32-1 on the Fireball Bullets, and it has proved to a good choice for AVL as well as cast iron. I suspect the TM in the picture I posted was nearer a TM38...
heloego
  • USA '12 C5, '06 ElectraX
Reply #37 on: August 21, 2019, 10:51:55 pm
I've a VM32 tuned for 6=7000 altitude.Love what it did for performance with a polished exhaust port and free-flow exhaust. I like the looks, too.
Only issue I keep having is the slide is finicky. Have to keep adjusting the idle up or down at stops.
It's not the cable. I keep it lubed regularly, and the slide with engine off doesn't stick at all. Tried lubing the slide with Teflon, but that didn't help.
Any suggestions?
'12 C5 Classic
Reply #38 on: August 22, 2019, 12:08:12 am
Any suggestions?
            Do you put a little Magical Mysterious Oil in your gasoline, petrol, benzine, whatever? I wonder if that might help??
            Cue Bilgemaster. He'll give you all the formulas (formulae?)  :) :)
heloego
Reply #39 on: August 22, 2019, 01:25:08 am
LOL. Got a bottle of MMO in the garage for awhile now. Forgot I even had it!  :o
I'll give it a try this weekend and see if it helps.
Thanks for the suggestion!  ;D
'12 C5 Classic
Reply #40 on: August 22, 2019, 12:46:22 pm
        I've found that just barely an ounce per two gallons seems to be OK. Keep an eye on your plug. It will tell you if you're using too much. Back in the '50s and '60s we all used what was then called top oil. Then we got unleaded gas and it was absolutely necessary for engines not yet built (or rebuilt) for it. I remember the first shovel I had the heads "built" on for unleaded. The total rebuild of each head was $500 each. The work was similar to what Ace did to my '08 AVL head. They were freaking gorgeous  ;D ;D
Richard230
Reply #41 on: August 22, 2019, 02:18:18 pm
I hate to say it, but I am still using "top cylinder" oil in the gas of my RE.  Seems appropriate, somehow. But now it is called by other names, such as fuel cleaner and combustion improver.  ::)
Reply #42 on: August 22, 2019, 05:47:34 pm
        But aren't most of those (not all) mostly just alcohol? I don't know myself. I don't buy much "bottled stuff for engines and gullible people". Whereas Magical Mysterious Oil is actually an "oil".
         I used to see a lot of "octane boosters" on the shelves also. I think they mostly boosted the profits of the auto store.
Richard230
Reply #43 on: August 22, 2019, 09:33:31 pm
I suspect that top cylinder oil and the like are just repackaged kerosene. Of course, I also believe the Marvel Mystery Oil is likely kerosene, too. But you do get a lot more of the stuff for your money.  ::)
Reply #44 on: August 22, 2019, 11:45:51 pm
Nope.
Marvel Mystery Oil doesn't smell like kerosene or coal oil and it won't light with a match like either of these fuels will.
Given enough time and heat it will burn but it burns like a light weight motor oil.
I know these things because I just tested it. :)
