15W is thicker than recommended. While it could be ok with monos that are quite older tech, it will not be ok for the 650. During hot summer periods it should be ok, but in winter it will cause wear and lack of lubrication until hot enough, if it can even reach "hot". This is how people bend conrods.
I'm skeptical of this. The 10W and 15W ratings are for oils at 0 degrees F. If you look at the viscosity vs temperature curves of any of these oils, you will see that the viscosity of a 10W oil at 0 degrees F ( -18 C) is MUCH thicker than a 15W oil at freezing (32 F = 0 C)
You can see representative curves here: Notice that viscosity is plotted on a LOGARITHYMIC scale.
https://www.engineeringtoolbox.com/iso-vg-grade-d_1206.htmlAt 212 F. both the 10W50 and the 15W50 have the viscosity of a 50 weight oil. As they head towards freezing temperatures, the viscosity increases radically. This temperature dependent change dwarfs the difference between the 10W and 15W.
This means, for example, that if you have 10W in your machine and I have 15W in mine, and you decide to ride at 28 F degrees, while where I live it's a balmy 32 F degrees, it's very likely that the oil in my machine is going to be less viscous at start up than your 10W.
If you ride at down to zero F, ( -18 C), you are a braver man than me, and perhaps you'll notice an appreciable difference between the 15W and the 10W, but I doubt it. I think that the _W ratings can be safely ignored by 99% of motorcycle riders, but the hot viscosity rating is quite important.
