Royal Enfield Motorcycles => Bullet with the UCE engine => Topic started by: palace15 on October 08, 2012, 07:48:36 pm
Title: LEDs again............sorry!
Post by: palace15 on October 08, 2012, 07:48:36 pm
Thanks to Singh and his youtube video I found that the bulbs I required are BA9s, but what is the Headlight pilot light code please.
And does anyone know a LED code for thr H3 halogen replacement that is not 46mm long, its too long for the light unit!
Just to say 2010 C5.
Title: Re: LEDs again............sorry!
Post by: barenekd on October 08, 2012, 09:10:24 pm
See the post in the Classic section on the BA9S-W vs -W4. I think the pilot bulbs are BA9S-W4, too. I've ordered a bunch of bulbs and the only other size I can find are BA7S and I think those were for the warning indicator bulbs.
Post by: gremlin on October 08, 2012, 11:40:21 pm
BA9  is the pilot,  I used a tubular 14 volt version .....  the spherical 12 volt versions may look whiter but they won't last as long.
besides, I like the yellowish look .....  seems more authentic.
Post by: mattsz on October 09, 2012, 12:33:13 am
Is the "tubular 14 volt version" an led?  What kind of bulb is this?
Post by: gremlin on October 09, 2012, 01:03:08 am
oops, sorry ....  brainfart.
I forgot this is an LED thread.
Post by: mattsz on October 09, 2012, 01:17:47 am
It happens... even to me!
But, while you've got our attention - what about the bulb?  Is there another thread that will answer my question?
Post by: TWinOKC on October 09, 2012, 01:43:26 am
http://www.enfieldmotorcycles.com/forum/index.php/topic,10412.msg120600.html#msg120600
Post by: gremlin on October 09, 2012, 11:19:59 am
I just went to the local AutoZone store and looked at their selection of lightbulbs.   They had quite a few BA9 type bulbs .....
some had large glass domes that exceeded 9mm in diameter, some had small spherical bulbs that were the same diameter as the base, and the one I picked had a 9mm diameter tubular glass dome, was rated at 14 volts, and the wattage was higher than the small spherical bulbs.
Whereas the bulbs with the BA9 base and the larger glass domes won't fit in through the bushing for the pilot lamp, the tubular style fits well, and, sticks out into the pre-focus area.
the 14 volt bulbs look a little yellow-ish compared to a 12 volt bulb - but they will last longer and *I* think the warmer light looks "correct" for the classic style.    reminiscent of an older 6-volt system.
Post by: mattsz on October 09, 2012, 11:57:54 am
Ah...  Thanks for that!
Post by: barenekd on October 10, 2012, 03:10:22 am
12 and 14V bulbs and other automotive and aircraft stuff are the same thing.
Most of them are just rated by name at the battery power, presumably. The actual electrical systems are 14V as that is what the stuff gets charged and actually are operated by the generator/alternator at the higher voltage. The 12V moniker is for folks that only know there is a 12V battery in the vehicle. Or in the case of some aircraft, 24/28V
The 14V is closer the the real world.
Again, no difference in the parts.
Post by: gremlin on October 10, 2012, 11:20:39 am
12 and 14V bulbs .......... are the same thing.
NOT
http://www.batterycentralmall.com/Batteries/XS_Power/xspower_batteries.html
Post by: barenekd on October 10, 2012, 06:08:19 pm
ARE
Post by: Ducati Scotty on October 10, 2012, 07:15:03 pm
They can be.  Healthy 12V vehicle systems can run anywhere from 12V to 14.5V.  Most auto specific bulbs are labelled 12V as a simple designation, but they're generally designed to handle any voltage that may come from a healthy system.  If it's not an automotive specific part it may be labelled with it's actual voltage rating, which would be a bit higher than 12V.
That said, I'd love to get some 14V bulbs for the speedo.  I'd like a nostalgic yellow hue to the lights.
Post by: gremlin on October 10, 2012, 08:40:10 pm
vehicle systems also come in 14 and 16 volt primaries.
check out this battery selection.
Post by: Jack Leis on October 11, 2012, 03:24:36 am
 Do I feel a storm brewing regarding voltages ? In the words of Rodney King, cant we all just learn how to swim ?
Post by: palace15 on October 11, 2012, 04:07:10 am
And the rascals have 'highjacked' MY thread to have their fight on! And I am still waiting for an answer to my original question! 8)
Post by: Arizoni on October 11, 2012, 04:43:07 am
Maybe a few rounds of Kumbaya while we all hold hands?  ;D
Post by: GSS on October 11, 2012, 04:49:24 am
Here is a list of LED bulbs that went into my 2010 C5.....http://www.enfieldmotorcycles.com/forum/index.php/topic,10412.msg120600.html#msg120600
With regards to the H3 halogen, why wouldn't you simply stay with the H4 style for the C5?  Is there any advantage of going with the H3?
I almost threw in a link to 16V automotive batteries, but that might lead to critical mass in your thread ;)
Don't worry.....Bare and Gremlin are good guys.....a spin around the block in their thumpers and the brotherly love will be back  ;D
Post by: palace15 on October 11, 2012, 05:18:11 am
H3 were to be for spotlights which I posted about on another thread, but it was suggested that 2x55w halogen spots may be a bit too much for the C5, so I was enquiring as to H3 LEDs and the possibility of H4 LED and use perhaps H3 Halogen........confused? .......I am!
Post by: gremlin on October 11, 2012, 01:33:26 pm
What's wrong with a well-intentioned flame war ?
I acknowledge 12 and 14 volt electrics are somewhat interchangeable.
by that, I mean to say 14 volt bulbs on a 12 volt system are OK.  However, I would caution against placing a 14 volt battery in your 12 volt vehicle.
.......   it's fun to nit-pick & have differences of opinion !
Post by: gremlin on October 11, 2012, 02:43:56 pm
an H4 LED will lower the demand, but, it won't be enough to account for the increase that a pair of 55watt H3's will add.
there are a variety of H3 style LED implementations available, some are totally worthless, and, others have varying sizes depending on the number of LED segments in their design.
If you can define your maximum size parameters I think a trip around eBay will be "enlightening"......
