Royal Enfield Motorcycles => 650 Interceptor & Continental GT => Topic started by: peter d on November 23, 2019, 12:38:41 pm
Hi have purchase a continental gt and would like the bars to be a little further back.While looking at the clipons they appear to be mounted slightly forward of the fork tube and I was wondering if I swapped them from left to right they would then be be slightly further back . Has any one tried this or fitted different clipons that are a bit further back.
Thanks Peter D
Several reasons it wouldn't work. Most notably is that you wouldn't be able to get the right control on because of the master cylinder hitting the clipon where the two allen screws are. They would be facing forward after you swapped them
There are protrusions that notch into the the upper triple to prevent clamp rotation
Pretty sure they would hit the tank after anyway
Here is another idea. I have seen clip on adapters that clamp to the top of the fork tube. They form a perch for a standard tubular bar. Then you could fit any style of handlebar you like. For example, a clubman style might give you the sporty look but more comfort and it would be easy to return to stock.
Thanks for the advice .
I'm lucky to have my Buell for comparing ergonomics with other bikes! The buell is very comfortable with at least 40% less of my weight placed on the bars
If you look at the rider triangle geometry and the measurements on the GT compared to the Lighting, the only difference is that the Lightning pegs are 3-3.5" inches higher
Doesn't seem like much but makes a huge difference in comfort and your feeling of control, it eliminates that hyper flexing in your lower back that pitches your weight onto the bars. Buell was also a racer and knew exactly what the ergonomics should be. WTF were the Indians thinking anyway??
https://youtu.be/kO4AztiYIC0?t=895
This rider is a lot taller than me so I can't speak to what he's experiencing exactly, but he definitely feels something's amiss. He rides all sorts of bikes for a living and he's generally not one with frivolous complaints. Even as tall as he is, his knees are still low on the tank.
I'm actually kinda glad the GT peg placement is so wrong for me because I have the opportunity to make it perfect, and I have the example to follow. It not as easy as it would first seem to accurately analyze less than ideal motorcycle ergonomics!
You can slide them down and pull them forward as much as you like
Thanks for your thoughts . Im 5ft 10 and when I tilt my head back to look at the road say 50 meters or more in front of me my neck pinches a nerve .If the bars were back about an inch my neck would be in a more natural position and I would still be able to look in the distance . I have just bought a new helmet an the situation is much improved but I think it would be even better with the bars moved back a little .
I looked at a GT and bought an interceptor for the same reason. The most refined option is to get an interceptor front top yoke and fit street bars to it. I went to other way and put peg re locators on it with lower street bars. After I stripped off the excess and fitted a single touring seat and cowl, it now looks like a continental with high bars and centre stand.
That sounds interesting. I would like to see what it looks like.
Can you post a few pics?
Here is the photo you asked for
That looks great!
