First-class job with the paintwork, as ever. Your tank looks to be identical to what I have on Not A Fury, it was even the same colo(u)r when I bought it cheap as an ex-display item from Hitchcocks' retail shop. A customer had bought and painted it, then returned it, claiming that it leaked.
I tried very hard to get it to leak, as did the guy who pressure tested it prior to painting it in its present finish, no fuel leak! My guess is that the first owner hadn't sealed the fuel tap thread properly. Never mind, it saved me some money.
Thinking about the damaged right hand headlamp bracket, how much would YOU charge to repair it? I probably could have it repaired locally, but your record is quite impressive.
A.
