Author Topic: Rear Axle  (Read 1109 times)
African Boy
on: June 30, 2023, 01:39:52 pm
Can you tell me what the parts are for the axle on the right hand side of the bike . First  axle shaft , next the the axle adjusting bracket/washer  .On the inside of the frame I have a large spacer . Is there another spacer that fits in the oil seal ? I feel there should be a spacer there but mine is missing . Attached picture of the right hand side of my bike . If you know the part number that would be great . Thanks
Reply #1 on: June 30, 2023, 02:07:28 pm
This was a misclick. If I could delete it, I would.
« Last Edit: June 30, 2023, 02:17:13 pm by tooseevee »
Reply #2 on: June 30, 2023, 02:14:41 pm
      I haven't been into that area of my bike at all, but you can find exploded views & every part number you need on Hitchcock's website. Just Click on the link that's at the top of the Home Page of this forum.
      It says: "Looking for RE Parts?   Shop Now".
Adrian II
Reply #3 on: June 30, 2023, 02:20:45 pm
From the very same on-llne parts book, is your missing item Part Number 141119, Distance collar, Rear Hub?
https://accessories.hitchcocksmotorcycles.com/1277?qty=1&continue_url=https%3A%2F%2Fwww.hitchcocksmotorcycles.com%2Fpartsbook-pages%2F6088
Item 3 on the exploded diagram here.
https://www.hitchcocksmotorcycles.com/partsbook-pages/6088
It sits in the oil seal, and goes back to the days when the speedometer drive was taken off the back wheel.
African Boy
Reply #4 on: July 01, 2023, 12:22:44 pm
Many thanks for your help .
