Author Topic: Meteor management light  (Read 2321 times)
sanpan
  • All the gear, all the time.
  • 2023 Meteor 350 Stellar Black
Reply #45 on: March 16, 2024, 04:15:53 am
Righty ho folks, here's an update.
So I'm back from a wee vacation and it was time to take the motorcycle to the dealership today, a Saturday here in NZ. I reached at 12.30pm only to later realise they only open till 12 on a Saturday!
Bummer, right? No!
As soon as I reached the dealership (a half hour ride) and restarted the motorcycle, the light is gone. Vanished! Okay! Had tried resetting it a million different ways but no cigar. However, clearly something was reset somewhere and the lights gone and has not come back after a half hour ride!
So I'm probably just going to buy that wee scanner, check any stored fault codes myself,  and not worry about this for now. The bike was running normal anyway.
Sometimes you do catch a break, afterall!
Cheers,
S
2023 - : Meteor 350 Stellar Black
2012 - 2023: Thunderbird (Rumbler) 2008
sanpan
Reply #46 on: March 28, 2024, 11:12:42 pm
Update:
About a thousand or so kilometres later, the EML light stayed gone, which is great. Also - my scanner finally arrived which I hooked up to the motorcycle today.
Ha! The usual suspect - error P0106 with the MAP sensor.
Shall I just go ahead and clear this one? Or let the dealer take a look regardless? The bike runs like a dream as before. My next service is not due for another 1000 kilometres.
Cheers,
San
SteveThackery
  • Inveterate tinkerer
  • "If it ain't broke, keep fixing it until it is."
Reply #47 on: March 29, 2024, 08:16:52 am
If it were my bike I would clear it and see if it comes back. It's very likely the dealer would do that anyway.
Meteor 350
Previous:
'14 B5
'06 ElectraX (Good bike, had no trouble at all)
'02 500ES (Fully "Hitchcocked" - 535, cams, piston, etc - and still a piece of junk)
...plus loads of other bikes: German, British, Japanese, Italian, East European.
60muzz
  • Gold Coast, Queensland, Australia.
Reply #48 on: March 30, 2024, 06:17:22 am
Dealers would see this as $$$$, Start changing all sorts of things, probably never resolving the problem.
If it ends up warranty then $$$$$, RE pays.
If you had a good rapport with your dealer/service group then maybe $$$ out of your pocket.
Yep, your own scanner, ELM327 from china, cheap as chips, hook it up to the EURO 4 connector,
cable and plug can be bought cheap as well, all up about $15.
You then have a say in what may need to be done if there is a real continuing issue.
sanpan
Reply #49 on: April 13, 2024, 01:11:44 pm
Update: Had cleared the code a couple of weeks ago.
About 600 or so kilometres of fairly 'purposeful' riding later, the code has remained gone.
Happy camper! These scanners are worth the money and then some!
Cheers,
San
Isla
Reply #50 on: April 13, 2024, 04:02:05 pm
Good to hear  :)
Shunpike Sister riding a bronze/chrome Classic 350 called Biscuit
sanpan
Reply #51 on: April 14, 2024, 09:23:09 am
Good to hear  :)
Thanks, Isla, and cheers for all the intel on the plug connector! Very happy camper!  :)
Cheers,
San
