Please note that I refer to "road bikes" as in "on the street"....(widely varying conditions)
I also refer to "racing" where I do say that there are often good reasons to change gearing based on the track..or even a particular corner.....a "high" third gear may work better than a "low" forth etc. and the shift point for a turn may just work out better with a certain overall ratio.....
But street riding is sort of infinitely variable...so a specific (extra high or extra low) gearing makes no sense (to me)
For street, if for instance, someone ONLY did city riding...never getting above 45 MPH...and lots of stop and go...and want to ride like a maniac in and out of traffic...by all means go lower in overall gear ratio...a lot lower...
so you will have 6 speeds of gears between 0 and 45 mph...but crap high speed performance ..but who cares if you are only in the city?
If a person had a long commute on an interstate highway where traffic runs a steady 80 mph....then a higher overall ratio would be justified....once up to speed.....shift to 6th....and run with low RPM...like an overdrive...smooth...quiet...economical...steady speed.....downside would be slow from a dead stop...(but who cares, you only start off once on that commute!)
But, if like most of us...we ride in the "jack of all trades conditions".....the stock gearing is very well thought out....
The bike is plenty quick off the line....and it will cruise nicely at 70 mph.....what more could you ask for?
Cookie
PS the reason that "middle gears don't matter" is that you simply shift to another gear. Gearing is basically an overall curve.....if we had a CVT the curve would be perfectly smooth, and the engine would run at peak HP the whole time (for high performance use).....since we have 6 speeds instead of infinitely variable...all you do is choose the breaks in the curve when we go from one gear to the next.....same curve....
Lower overall ratio just moves the entire curve to the lower ranges...and higher gearing just moves the curve up...only the endpoints are different...the curve doesn't change....the shift points change...but the curve does not....
I f you look at he charts I posted in another thread...by changing gear ratio some weird stuff happens..like the new "forth gear is actually a lower gear then the old third!!!! but notice the whatever the ratio...the curve is unchanged except for the starting point and the ending point..
But for "recreational riding"...on the RE.....we have a broad torque band.....and we have 6 speeds, and we typically don't do max performance pulls from a dead stop to 80 mph.....so at a given speed...the bike will run just fine in several possible gears! This is a feature which make the RE so enjoyable to ride. A bike with a ;narrow poer band which is at say 9000 rpm....is really fast, and really powerful....but has to be driven and shifted carefully and correctly.....the RE? Ah whatever!
That's not always the case. I use a 14t sprocket on my supermoto for go kart tracks and a 15t on full size ones. the bigger sprocket lets the motor pull a bit longer in each gear, lets the bike be in a better gear for faster corners as well as giving a better top speed for that long back straight. Everyone else I know who races or takes track days seriously has different sprocket sets for different tracks. I know what you're saying, that in the intermediate gears you can get the same speed just in a different gear but there's more to it than that. The 14t is good for wheelies, too. I haven't tried a 16t but it would probably be a good thing except that apparently it brings the chain too close to the crankcase with grindy results. A 6 speed box would be even better. Thanks for nothing, Suzuki.
