So, you consider 1st gear to be too low.
I consider it to be just right or slightly too high. Go figure
I also consider 6th gear to be on the high side....but nice as an overdrive...its there if you need it...doesn't need to be any higher though..
If you change ratio by one tooth, the change will be slight....so slight so as to have a very minor effect. Why bother?
If you change the ratio by several teeth...you will have a big change...and will have a negative effect on starting out in 1st. Slow off the line if you will....
Most discussion on forums concerning 1st gear ratio has to do with LOWERING the gear, to allow for quicker off the line, jack rabbit starts....makes sense, sort of..
Then when discussing higher gear ratios, most are concerned about high speed driving, like on a highway , in 6th, toget the revs down for long trips at high speed...sort of an over drive or cruise gear...this also makes sense, sort of.
But raising gear ratio, to "improve" 1st to 2nd gear shift, achieves neither of the above aims.....
you want to shift to 2nd at a higher speed, and / or a lower rpm.....but I don't see any need for this, much less any reason for this....
Changing sprocket ratios only effects starting out in 1st, and cruising in 6th.....(yet some will argue that every ratio is different for 1,2,3,4,5,6....but really it only changes the shift points...not overall change in "performance")(this is an arguement we can have at a later time)
Stock, you can now shift from 1st to second at any speed you choose form 0 to 45 MPH! That is quite a wide range IMHO. My lower powered bikes, can only go 15 or 20 mph in 1st....
Of course a high powered, high revving bike can go anywhere between 0 and 90 MPH is 1st.!!
Based on power available, and red line at 7500, I think RE got the gearing just right, for all around driving!
Change your ratios...try it out....won't hurt anything, except possible drivability...who cares?...go for it...have fun...see if you like it....please yourself!
But keep in mind....changing something should be for a good reason...changing for the sake of changing is pointless...
Bigger is not always better (contrary to the "American" philosophy)....better is better..
Cookie
I'm not doing well on these replies to individual posts am I ?😱
