Hello All
OK, time for a question!, whilst working on my bike I have come across a strange issue with the TCI unit, the bike was running fine with the large TCI unit that came fitted, but that being said I do not really know how the bike should run anyway, I have brought an up rated green TCI unit from Hitchcocks, but am now faced with connector plugs that will not fit the new unit
You can see from the photo, the old unit is so much larger than the upgraded unit, is the old larger unit a previous model?, or might it well be off another make of machine altogether??.
Could someone please post a photo of their own bike, with the standard setup?, showing how the unit is mounted and what colour wires go into what terminals on the upgraded unit?, I do not know if I can get the correct terminal plugs separately, if not, then I can, not ideal
, just put some female spade conductors on the loom wires and connect them individually to the upgraded TCI unit.
I also note that the sidestand switch has been removed, cannot see exactly where in the loom it has been cut from, will take a closer look, not that I need a switch to tell me the sidestand is down, but I see it should plug into the TCI unit, will it make a difference if it is left off?.
Check out the household 240 volt cable spliced into the loom
, oh the joys of a previous owners handywork, little hidden gems waiting to spring out in utter disbelief
Thank you in advance,
John
