General Discussion => Sidecar Talk => Topic started by: 500KsGerry on August 20, 2011, 09:23:50 am
Title: side to side wheel base?
Post by: 500KsGerry on August 20, 2011, 09:23:50 am
What is the distance of the sidecar tire from the center of the bike on the cozy/RE set up? Just curious, Haven't gotten to the chassis /frame build yet. Appreciate the info so thanks ahead of time . Gerry
Title: Re: side to side wheel base?
Post by: The Garbone on August 20, 2011, 07:18:57 pm
Check here ====>  LINKY (http://advrider.com/forums/showthread.php?t=468196)
I will go out and measure mine, but I know the slip joint do allow an inch or two of adjustment on the width..
Post by: 500KsGerry on August 20, 2011, 07:48:07 pm
Excellent linky there Garbone . Thank  you! Some  good  info .
Since this one will be a 2/3 leaner to start with I will be going for the zero-scrub. Was good  to confirm  that on  your link.  Combined with the chair being narrow/kinda short, with the seat center between the leading edge of the rear  rims and the swing arm pivot points will  provide about 1 square foot of optimal area for load (butt). Does make for a small area for CG  so very minimal cargo will be able to stow in the nose. It's mainly a puppy/grand kid chair anyhow.
 pic added of basic design though not to scale
Post by: GA-DK on August 21, 2011, 01:00:03 am
Mine measures 46.5" from and to center if tires.  It could be set up about 1" less or a few inches more.  My Cozy Euro is fitted with mounts of my own design.  I would never use the monstrosities that CMW sells as a G5 adapter.  It would totally block the kickstarter and would be very weak and bound to crack in a short time.  All in all a very poor design.  GA-DK
Post by: 500KsGerry on August 21, 2011, 09:09:59 am
Mine measures 46.5" from and to center if tires.  It could be set up about 1" less or a few inches more.    GA-DK
This  is  great.  Was thinking 42 inches max  for  mine...skinny  car.  Can't wait till I get to fiddle with the geometry  of the actual parts some more to see how narrow I  can get it all with the needed  clearances. Thanks GA-DK
Post by: 500KsGerry on October 01, 2011, 11:15:31 pm
Ended up at 44 inches on  build. Thanks for the info  guys. Gerry
