Royal enfield is doing little bit changes here and there for improving the bikes reliability recently seen that the newer bikes
1.have sorted the problem of seat like earlier bikes seat is shaking but now seat is firm and there is no up and down movement
2. Clutch wire has been changed now there is wire strap for holding the wire it's a metal strap that is fixed on the LH side indicator nut moreover the clutch adjustment on the clutch lever is now changed to split type earlier it's one piece
3. Quality of relays has also improved
4. Fitted small magnet in petrol tank near the fuel pump
