Author Topic: Interceptor Soft Panniers  (Read 6269 times)
9fingers
  • From the New Hampshire part of New Jersey
Reply #15 on: December 08, 2019, 11:41:39 am
I bought a nice 30l Ogio tail bag, which is fantastic but obviously no good for two-up. Ogio makes companion saddlebags that collectively make a serious 3-piece kit that would hold weeks' worth of stuff. I'll probably end up with either that or the Givi hard panniers that Hitchcock has on the site. Those look solid. Each of the hard panniers is 20l and since they rest on a frame, they don't conflict with the pipes apparently. But they're not soft panniers, which is what the OP was asking about, I understand.
If (when) I get an Interceptor, I will probably go the same route that your taking. Hitting the NYC bike show today and will give it a more serious look.
9fingers
Currently own:
2016 Classic Chrome Maroon
2020 Moto Guzzi V7III Special
V Strom 650 ABS Adventure
Beta Rev 3 270
Honda TLR200 custom
Honda TL 250 TMI custom frame
Honda TL 125
Yamaha TY350
jimku
  • Nampa, Idaho USA
Reply #16 on: December 09, 2019, 08:12:42 am
HERE YA GO MATE!
https://royalspares.com/products/brand-new-royal-enfield-interceptor-650cc-saddle-bag-carrier-pannier-mounting-set
You can cut the tabs that go to the top shock bolts off with no problem, they are still rock solid.  Those shock bolts are so tight that is virtually impossible to get them out and back in without screwing up the shallow indents in them for the hex wrench and having to resort to a pipe wrench and ugly buggered-up bolt heads.  Also, on my Interceptor I had to replace my rear turn signals with shorter ones to eliminate interference with these mounts.
« Last Edit: December 09, 2019, 08:16:47 am by jimku »
2019 Interceptor.
I hope my tubeless wheels make you cringe. 8) https://www.dropbox.com/s/zobmpjq2gqtvypj/RE%20TIRE%20AND%20WHEEL.JPG?dl=0
Sometimes you're the windshield, sometimes you're the bug.
https://youtu.be/GG5ghP8XLW8
olhogrider
  • Classic 350 Desert Sand
  • Blue Ridge Mountains of NC
Reply #17 on: December 09, 2019, 07:49:54 pm
HERE YA GO MATE!
I want to see those mounts without the bags on them ;D
jimku
  • Nampa, Idaho USA
Reply #18 on: December 09, 2019, 10:16:16 pm
My bags are only removable by removing 12 bolts that hold the bags to the mounts. See, it's like this here:  I don't consider any bike without decent saddle bags and a windshield worth squat, so I never intend to remove them.
2019 Interceptor.
olhogrider
Reply #19 on: December 10, 2019, 05:40:53 pm
Fair enough. I have great bags and windshield on my Triumph but I like the ability to get naked with the Interceptor. I was really just curious about how those mounts are mounted.
Ove
Reply #20 on: December 10, 2019, 10:45:47 pm
If I had those bags I'd want to be able to remove them (& probably  put them back on ebay :).)
