Author Topic: 1955 super meteor return oil pump issue  (Read 12899 times)
0 Members and 3 Guests are viewing this topic.
AB55TB
  • I love anything with a motor
Reply #30 on: June 03, 2013, 08:13:53 pm
ERC...hey!!! It's a great day!!! I got the oil return tube apart an cleaned out, an also got engine block unplugged... It had many years of build up in it, but all is clear now  ;D thanks to a 15mm floppy ratchet wrench, an your pointers ERC it all came apart.. Plus I had to take some stainless cable on a drill an run it through the oil ports to clean them out...them a little air an spray cleaner all is good now  8)
Reply #31 on: June 03, 2013, 10:44:15 pm
That's great I knew you could do it with a little patience. If the return pump is ok you should be golden.   ERC
AB55TB
Reply #32 on: June 04, 2013, 02:41:38 am
ERC...yes it's in good shape it's all been replaced new,getting ready to do the seals on the stater side, hopefully it won't be to bad  ::) if you know of any tricks to getting that clutch friction plate off with out bending it I'm all ears haha!!
« Last Edit: June 04, 2013, 02:44:41 am by AB55TB »
Reply #33 on: June 04, 2013, 11:00:52 pm
That's great, the clutch friction disc is rivited on. If it's not badly worn leave it in place other than that drill the rivets out to remove it.  ERC
AB55TB
Reply #34 on: June 05, 2013, 03:56:42 am
ERC... The seal behind the clutch an the seal behind the stater need replaced, so does the big nut on the crank have reverse threads? Was hoping I could take a puller an take the back of clutch out to change seal... ???
Reply #35 on: June 05, 2013, 02:55:12 pm
The nut is right hand thread. You just remove clutch basket, stator, chain the whole assemblies. If the inner primary is original it will have felt seals in there. When you install the engine sprocket be carefull you don't pinch the felt between the sprocket and crank.  ERC
« Last Edit: June 06, 2013, 12:51:32 am by ERC »
AB55TB
Reply #36 on: June 06, 2013, 03:20:16 am
Ok thank you so much ERC...I'm down to the big nut an it looks like someone tried to take it off before cause it has chisel marks on it, but I think a socket will still go on it...just hope the 1/2 inch impact with 3/4 socket adapter will take it off  ??? I'm trying to deal with
Nfieldgear.com on the parts, but the number plate is gone from this bike an I don't know what to use to look up my parts...so I emailed them about it, but no response yet.
Reply #37 on: June 06, 2013, 04:31:35 pm
Go to Hitchcocks site they will have parts diagrams that will match.  ERC
AB55TB
Reply #38 on: June 07, 2013, 04:02:17 am
ERC...yes that's where I've been looking at everything  but was just hoping to deal with a company in the US cause shipping is so much dealing with hichcocks  :-\
Reply #39 on: June 07, 2013, 01:44:49 pm
They really are the only game in town that has the parts for these bikes. They're great to deal with though.  ERC
« Last Edit: June 07, 2013, 06:11:39 pm by ERC »
AB55TB
Reply #40 on: June 07, 2013, 04:05:25 pm
ERC...yea they do have a lot of stuff, but we are needing other parts for the bike an Hitchcocks are saying they are no longer available  :-\
Reply #41 on: June 07, 2013, 06:23:00 pm
You can go on the Brit Bike Forum and put a request in there under the Royal Enfield part. You may have some luck there.  ERC
AB55TB
Reply #42 on: June 07, 2013, 08:43:29 pm
ERC...Ok thank you.
