General Discussion => Tech Tips => Topic started by: rtillery02 on January 25, 2018, 03:18:24 am
had an intermittent electrical gremlin eat'n my lunch for a while, the subject indicates the symptom. Located the culprit @ the relatively new tail light assembly. Thanks Arizoni for keepin me on the suspect lighting circuits & switches. Any recommended tail light upgrades? don't really wanna put the third assembly of this type back on.
I replaced mine with a Model A stop light. See photo. It could be brighter, looks good.
Very nice, was it equipped with spade type connectors & the same mounting bolt spacing, or did you need to create new holes & add connectors? I did see that type of light assembly during my search but there really wasn't much info about it besides just the image. While I'm waiting on a replacement, I've epoxied the broken one back together, it functions properly but for how long? Hopefully till my new one gets here.
If I remember correctly, it came with bullet type connectors, I just snipped them off and soldered on some spade type connectors from the auto parts store. Then slathered those connections with a dab of dielectric grease and followed with a wrap of electrical tape.
As far as the mounting bolt spacing, I seem to remember some fiddling, I may have enlarged the existing holes or made new holes,..........whatever I did it was not enough of a problem to become etched in my memory.
And thinking about it a bit more and looking at the photo, I now remember that I did drill two new holes in the taillight bracket. The two attachment screws on the Model A light, are narrower than the stock mounts. If you look very closely at my photo you can see the stock bolt hole just to right of the STOP light.
When I broke the original factory tail-light, I epoxied it back together, and it held for over three weeks til the new light arrived, and is still holding together unto this day (in a box in my junk drawer).
As we all know, as long as you have that replacement on hand, the epoxy will not fail.
Damned straight it looks good! If my OEM light goes south, as they seem prone to do, I'm likely to "go Model A" as well. Hell, my lens is already not properly mating flush with its base...Maybe I should start shopping now.
Ya gotta love that STOP .
It reminds me of the old tires sold by Firestone back around 1909- 1912.
The tread pattern repeatedly said NON SKID NON SKID NON SKID... ;D
