Author Topic: 7" Halogen Headlight  (Read 2935 times)
PaulF
on: June 04, 2008, 03:52:13 pm
Does there have to be an upgrade in any part of the chrging system to accomodate a 7" halogen headlight or will it be just a plug&play?
Thanks,
EnfieldJake
Reply #1 on: June 04, 2008, 04:08:00 pm
For my '06 Electra it was plug and play without any issues. For reference, I'm using a Sylvania Silverstar sealed beam halogen
« Last Edit: June 04, 2008, 04:10:28 pm by EnfieldJake »
Bankerdanny
Reply #2 on: June 04, 2008, 07:58:39 pm
It was plag and play for my standard Bullet too.
And a VERY worthwhile upgrade.
Endeavor To Persevere
Current: '75 Honda CB550F, '76 Honda CB750F. Previous:  2007 Yamaha Vino 125, '75 Harley FXE Superglide, '77 GL1000 Goldwing, '77 Honda CB550K, '02 Royal Enfield Bullet 500ES, '68 Suzuki K11, '68 Yamaha YR2, '69 BMW R69S, '71 Honda SL175
PhilJ
Reply #3 on: June 04, 2008, 08:17:40 pm
Thanks,
Which model RE to you have? If it's an older model there could be a problem as the alternator doesn't have a very high output.
PaulF
Reply #4 on: June 04, 2008, 08:49:47 pm
Thanks,
So I wasn't imagining things. I thought I had read somewhere about a regulator/rectifier or alternator upgrade and wanted to confirm that, thanks.
Its and 08 AVL motor so I guess I'm good to go.
PhilJ
Reply #5 on: June 04, 2008, 09:50:15 pm
Oh yes. Mine is too and I put T-Bar head lamp in mine. All works well.
Good Luck.
scoTTy
Reply #6 on: June 05, 2008, 04:54:10 am
blue dot  here 2.. also  turned off the light when starting
