Over about fifty years I’ve experimented with timing on a variety of engines that I’ve owned. My preferred technique is to gradually advance the “static” setting from that normally recommended until the engine just pinks, then to back it off again until it doesn’t.
This has made me realise that manufacturers are often quite conservative in their published figures.
For example, one car manufacturer recommended TDC on their 850cc four cylinder engines. I had mine remanufactured and then modified and tuned it, fitted twin carbs and a performance cam etc. Due to an error at the engine shop, it had a very high compression ratio (13 to 1). It ran best with 17 degrees BTDC, using super unleaded fuel. I backed it off to 14 for peace of mind.
I have a 993cc, three cylinder engined Suzuki Swift (Geo Metro to our friends in USA), which I use to commute to and from work (45 miles each way). The “book” static setting is 5 degrees BTDC. I tweaked mine to 15 BTDC and it runs much better.
Annoyingly, my iron barrel, 350 Bullet Electra has no facility to alter the ignition advance, or even to check what it is.
