At around $230 Au landed my first thought upon seeing the flyscreen was - it was extremely over priced!...lol
after all you got was a headlight surround and a 5" bit of curved plexiglass and 4 screw with nuts ...lol. the assembly side was pretty easy though- no instruction included but 5 minutes later and all together
fitting it to the bike was also easy. out with the old housing by undoing the 3 screws and in with the new......but as usual a slight problem. hitchcocks had sent me the wrong housing tongue with the headlight housing. probably for the iron barrel model. the old headlight housing would not bed in and pull the new together as the tongue was way too short. I decided to switched back to my original unit but no luck there- it was too long
friggin life story
anyway back on the computer to hitchcocks with an email and a week later a new clip finally arrived and this time a perfect fit in the housing. although they did say it had not happened before....sure!
after that it was on the bike in no time at all. very neat fit too.
first impression.
for what it's worth it looks highly expensive and really overpriced compared to the dx universal windscreen. one screen looks like you got your $230 worth of plastic and the other -well the hitchcocks - you got something but I am not sure what ...lol
but that's where the buck stops! both screens work well but surprisingly and I mean surprisingly this sawn off little buggar is by far the better unit.....repeat BETTER UNIT!
don't ask me why - but it work and work extremely well. I still find it hard to believe how really good this screen really is.
remember I ride with normal handle bars and full face and - for those who came in late c5 4
- today while riding at 60 mph I removed my left hand off the grips and placed it in front of the speedo area - no wind moved up a few inches still non -up chest level - slight but not much- visor up but sunglasses on still not much wind hitting me.
today could have been the perfect day for me to take up smoking while riding and combine two pleasure at once but I don't smoke...lol
anyway I then decided to try the old flat out on the tank position to see what the wind resistance was like there - no difference whatsoever. exactly the same as the upright position so whoever set up the angle for the flyscreen -its perfect not even close PERFECT!
unlike the universal dx which takes quite a while to fit and set it up and test ride and adjust then test ride then tighten and so on and on .. plus it picks up handle bars vibes. -not so with the hitchcocks learnt this off the younger ones -plug and play...how's that
I also noted at 60 mph that I had more get up and go on tap and it was quicker to the 70 mph so no doubt its cutting through wind resistance very well.
I also think it would be good for an extra 5 mph top speed why because the day earlier I hit 75 mph easy...lol
so earlier where I thought this could be an overprice bit of decorated plastic with chrome trim and had plans to get rid of it and keep the dx large screen - the dx is going and this ones the keeper.
I've trialed it over 120 miles and its still rock solid and its pretty cold here too. today at 8 degrees c I forgot what it was like being hit by that cold air in the chest area as you just belt along at 60 mph....really is nice.
to sum up mounted on the bike its hard to believe something like this
could be better than this
but when you have both units to do the review - its an easy answer and hitchcocks wins the test.
to conclude this wasn't all my doing. "bare" told me how good this screen really is and I thought only way to find out for myself -buy one and try -he's right and a good call!.
