I always add a fuel filter to any motorcycle I have had, except the K75 which already has one
, as AzCal Retred put it so well, nothing will work if it gets full of muck, maybe not an issue with you're tank uvellani, but it certainly won't hurt
Well as long as it does not leek.....
I should add that I am with others on this, initially make sure what you have is in good order, ie the float valve, it is possible for the valve to sometimes get stuck, or perhaps a bit of debris, the black Viton tip should be smooth, with no ridges, although you can often see a mark where it sits up against the brass female part of the valve, but it should not have an actual wear ridge.
Changing this one item, the valve assembly, can give a carb a new lease of life.
John
