Author Topic: Loose axle bolt  (Read 1859 times)
Nightwalker
on: June 15, 2020, 02:49:03 am
I got a bit of a shock this morning to see a loose axle bolt sticking out. It’s not the main axle bolt and to be honest I don’t know what the purpose of this bolt is.
Could anyone tell me what this bolt does? I assume it’s safe for me to tighten back in. I have no idea how it became so loose. Bike was serviced 2 weeks ago!
NVDucati
  • USA 2020 INT
Reply #1 on: June 15, 2020, 03:18:22 am
Good chance that the service shop put it there to use a "pit stand" while they worked on your bike. The forgot to remove it.
Member: AMA
Current Rides: '14 DL1000 ADV, '06 SV650N, '93 900CBRR, '74 Ducati 750GT, '14 Honda CB1000-R
Roshiba777
Reply #2 on: June 15, 2020, 05:39:59 am
This bolt is used for fixing the bobbins for use of paddock stand
Royal Enfield CI 500 (2000)
Royal Enfield STD UCE 500 (2010)
Royal Enfield Classic 500 (2011)
Royal Enfield Classic Chrome 500 (2011)
Yamaha RD350 (1988)
Royal Enfield Interceptor 650 (2019)
Bilgemaster
  • Just some guy
  • Global Moderator
Reply #3 on: June 15, 2020, 12:55:44 pm
Kinda makes you wonder what else they forgot, huh? Reminds me of the time I got some new tires at the local NTB joint (now called "NTW"), went out to drive it off, but discovered in a cursory look around at my nice new rubber that all the lugbolts were just on there finger tight, if that.
Richard230
Reply #4 on: June 15, 2020, 02:02:19 pm
My observation would be: if they had installed a shop stand bobbin, they obviously had removed it. But why would they reinstall that funky screw?  My guess is that they didn't use a bobbin to lift the rear of the bike but instead used the cheap screw as a replacement for a real bobbin and then forgot to remove that.
Anyway, I recently installed swing arm bobbins on my 390 Duke and I sure like that method of lifting my rear wheel than relying on stand arms located further forward under the swing arm. Of course, in addition to the bobbins you will also need the "Y" shaped attachment to your lifting stand to make that lifting method work. But once you invest in the "Y" attachments they will likely last you forever.  :)
rowdyyates
Reply #5 on: June 15, 2020, 03:10:29 pm
Cowboys. That is why I wont take my bikes to a garage/dealer. What else are they forgetting to do or just not doing on purpose. They wanted £200 for the 300 miles service. I told them to fuck off. One of the dealers who I spoke with admitted that they do not even do the valve checks until 6000 miles. I wonder what oil they would use? Some shite no doubt.
1988 RGV 250
2020 RE GT CONT 650
58webbing
Reply #6 on: June 16, 2020, 09:16:21 am
Take that bolt right out, do not tighten it as it will cause a lot of damage. Most dealers try to frighten you into getting them to service a new bike by threatening all sorts of doom if you do it yourself. I have never in my whole life (3 score years and 10+) known a dealer carry out any work on any vehicle to my satisfaction. My friends who dont agree with me, at my suggestion put secret marks on items that would have to be disturbed during a service only to find that they were not touched.
2019 Royal Enfield Interceptor
2019 Honda CB650R
2020 SurRon Light Bee
2018 Royal Enfield Bullet
2022 Royal Enfield Meteor
olhogrider
  • Classic 350 Desert Sand
  • Blue Ridge Mountains of NC
Reply #7 on: June 16, 2020, 09:10:43 pm
Only if you get the metal ones. I got the plastic ones for my Triumph and they melted! :o
Richard230
Reply #8 on: June 16, 2020, 10:12:15 pm
Yikes! Why would anyone make a set of plastic "Y" fittings for a rear wheel service stand? That seems like asking for trouble.  :o
olhogrider
Reply #9 on: June 16, 2020, 11:09:26 pm
I think the people who make them didn't factor the location of the exhaust. It comes out right at the bobbin.
rowdyyates
Reply #10 on: June 17, 2020, 10:32:28 am
Hitchcocks do a nice paddock stand and bobbins. I have one and its great.
1988 RGV 250
2020 RE GT CONT 650
OLD FELLA
  • Retired from racing but not life!
Reply #11 on: June 17, 2020, 01:03:44 pm
Talking about plastic bobbins not the bobbin lifting fork ("Y")  ;)
Richard230
Reply #12 on: June 17, 2020, 02:31:53 pm
Oh, that makes more sense. In that case, I can understand plastic or nylon bobbins being a thing. The ones that I have on a couple of my bikes are some sort of plastic and they work well, especially the ones on my electric motorcycle.  ;)
