Just to follow up with my experiences regarding this stopping dead issue.
First of all...when I was considering buying a RE interceptor, I watched a lot of videos...one of them showed a guy in India, riding his brand new bike home from the dealer, and the bike stopped flat dead! Hmmmm??
Now it seems that many people are experiencing the same issue
Hmmmm???
Gee...a bike made in INDIA, which is a "copy" of a bike made in England...you know those English bikes known for crazy electrics, and now a poor copy of that! What could possibly go wrong?
So electrical problems didn't surprise me...
My first problem was definitely in the ignition key switch....If I turned it too far clockwise, the bike would not start...also when riding, if it vibrated too much, the bike would stop....in either case just a jiggle of the key would solve the problem....I finally disassembled the key switch, and IMHO it is designed and constructed like crap....I could see how easily the switch could "overshoot" the contacts, thus cutting the ignition...
So I eliminated the key switch all together and installed a heavy duty, automotive, waterproof, toggle switch....this cured that problem.
But then the engine dying problem started...where the ignition and fuel pump were shut down, yet the ignition stayed on (lights on the instrument cluster stayed on...)
So my first suspect was the sidestand safety switch...because I rebuilt the kick stand, so I figured I messed up the switch...I inspected, tested, and cleaned up that area..and went 2000 miles without issue...
Then the sudden stopping came back!
Next suspect was the roll over sensor (because my dealer told me they had to replace several of these under warranty on customer's bikes)
So I bought a salvage roll over sensor, and disabled it by disassembling it, and gluing it with crazy glue, permanently in the "upright" position.
I've gone another 1000 miles , maybe 1500 with no further issue....
Did I solve the actual problem??? No way to know! You can't prove a negative!
If the problem comes back in the future, then I did not solve it.....I will have to move onto to some other fix..
If the problem doesn't come back, then I fixed it. not very scientific is it?
Cookie
