Hi Twocool, certainly try different fork oil first, something heavier will give you both more compression damping, and more rebound damping, which seems to be what you are complaining about.
as for the rear shocks, you mentioned that they are "rebounding quote slowly", so it seems they have plenty of rebound damping, which is what you want. If compression damping is to light and rebound to slow, the rear shocks can "pack Up" in a series of bumps and end up basically fully compressed. The same goes for the front. I think Harris Performance and RE did really fine job with the suspension, so there must be something wrong with yours. My bet is that the forks oil is low, contaminated, out of spec, or whatever. Companies like Hagon and Falcon make good rear shocks for not that much money. I use Falcons, tuned for my weight, on all of my trials bikes. I get them directly from Falcon in the UK. You missed a spectacular 180 mile ride up to the Catskills today, and a great BBQ lunch.
And ice cream on the way home! Next time.
9fingers
