Author Topic: How to adappt the front forks.  (Read 1023 times)
Hans
  • Most miles are done on my pickup..
on: April 15, 2024, 05:19:00 am
Hi, I have a 2021 Classic 500. and I want to add a sidecar.
Now, to reduce the trail , I am thinking about fitting offset axle front forks.
Would that reduce the trail enough for sidecar use, or should you do something more drastic ?
I guess the best would be to have a set of Earles forks made up.
Not sure I want to go that far.
Maybe leading links ?
Look for stiffer springs, or dampers ?
Any ideas out there ?
Thanks,
Hans
axman88
  • Vintage Motorcycle Fan
Reply #1 on: April 16, 2024, 07:47:35 pm
It might be fairly straightforward to adapt a set of forks tube assemblies, or just the lower sections, from the pre-2012 C5, which have the axle offset forward.  I recall reading that this fork design was kept later still on Bullets and/or 350 machines.
https://www.ebay.com/itm/276346496791
https://www.ebay.com/itm/362965606614
I believe, at some point the method of mounting the tubes into the casquette changed to be alert.
One could also reduce wheel diameter to reduce trail.
AzCal Retred
  • Chennai Wrencher
  • a journey of a thousand li starts under one's feet
Reply #2 on: April 17, 2024, 03:37:05 pm
Since you are buying a sidecar, what does the manufacturer suggest? They certainly have set-up guidelines. It's poor form to kill off your customers! ;D  I'm betting this is a well travelled road. Try these folks, they are a known good supplier:
https://www.cyclesidecar.com/sidecars-for-motorcycles
You don't particularly want to become a test pilot for a low-budget "no-name" brand sidecar builder at our age. It's frustrating and we no longer "bounce"... :o
A trifecta of Pre-Unit Bullets: a Red Deluxe 500, a Green Standard 500, and a Black ES 350.
zimmemr
Reply #3 on: April 19, 2024, 01:41:33 pm
I'd mount and ride the sidecar before worrying about modifying the front fork. Over the years I've owned several rigs and built a few for others. In my experience, a light bike, with a light sidecar normally works just fine with stock geometry. I would recommend installing stiffer fork springs, wider handlebars and a steering damper, and of course lowering the gearing. You may also want to invest in stiffer rear springs.
FWIW my T140 Triumph with it's Watsonian Palma chair would positively smoke my buddy's BMW R60/2 Steib combination. ;D But when another riding buddy bought a factory-built HD hack, he put us both on the trailer. :o
