Author Topic: Delay in clutch full disengagement Machismo 350 year 2005 model  (Read 934 times)
Vishreddy
Hi, recently I tried to adjust the clutch cable on my Machismo 350 (AVL) by fiddling with the screw next to the kicker by openings the plate which has 5 speed on it. Since then, when I am in the process changing gears the engine keeps revving for a few seconds after clutch lever is fully pressed and throttle in the zero position. Initially I thought it is the throttle adjustment cable, but now I feel it is the clutch that takes a while before it completely disengages because this happens only in movement and does not happen while in neutral. Please let me know if anyone has faced such a issue and if there is any solution.
Thanks.
Vishwa
