Royal Enfield Motorcycles => Bullet with the UCE engine => Topic started by: reuter on September 10, 2009, 03:56:39 am
When i was removing the oil filter front plate it kicked a bit knocking the washer and the small oring loose in the casement. what came first? I don't know. does it go oring washer then the cover or does it go washer oring on the post then thread it through the other filter elements. WTF not a single schematic or drawing description about this any where..
Who has done it i need a hand
thanks
r
Hello Reuter:
I have attached several pictures of oil change / filter for UCE in another thread called "UCE Oil change" started by Gashousegorilla just a few days back. Check it out.
