I have the US version of the Interceptor, INT650 for the USA. Anyway I do not like the turn signals and am wondering if anyone has replaced them? If so what did you replace them with?
I did. I mounted LED bar end signals where the stock one were.
I have seen Dan's personally , they are small, indiscrete, and very bright.
Did you have to replace or add a relay to get the LEDs to flash properly?How did the fitting work out for both front and read? Do they just thread right on?
I did get an adjustable flasher, also from Amazon. Comes in a two pack. The lights do just screw on but the rear will be hidden behind the stock taillight. I have a smaller, round taillight so it's not an issue.
Where is the flasher located, and is it two terminal or three?Thanks, John
