I finally got my 56 Indian Tomahawk (aka RE 500 Twin) running. Way too many kicks. lol It ran great for about a minute as I was lightly revving the engine then, I thought I would see if it would idle. It died. I figured it would start up right away.... Wrong! many many more kicks and it fired up but was running very rich and didn't want to clear itself. It died again. I have checked main and pilot jets, and they are both clear. I am guessing I need to check float level next. I had this same issue with my 55 Indian Woodsman. Float level was way too high causing the bike to easily flood.
I have two questions. I only have one lever on the bars (not including clutch and brake) and it's on the right handlebar. I believe it is for the jet block in the Amal 376 carb. I believe the bike has an auto advance set up in the engine so no retard/advance lever. I am not familiar with the jet block but believe once you open the lever you are blocking air flow through the venturi essentially, acting as a choke. Am I correct in that assumption? although, my 55 Woodsman had a 376 Amal, it did not have the jet block lever.
Does anyone know the correct starting procedure for a Royal Enfield 500 twin? I would think, tickle the carb, open up the jet block lever, give a little throttle when kicking. Does that sound about right?
Any and all thoughts are appreciated.
