This is Tom’s original performance review on the thread of the original design thread. He was running his GT535 with the first run of the Air Kit set up.
Everything fit correctly, no modifications needed, no mess, no fuss, and done in about 10-15 minutes.
Ride Report:
I did a before/after, so that I would have a good basis for commenting.
The idle did not change. Still started up with one press of the button, and idled like a clock.
Coming off idle onto the road in first gear, it felt stronger. Pulled out with better authority than before.
Shifting up thru the gears, it pulled better and revved more freely all the way up above 5000 rpm, which was as high as I went. The bike felt less strained, revved easier, and seemed to have less vibration at speed, and 65mph felt more comfortable.
I took it up a slight hill with the throttle wide open and it still only went to 4500 rpm on the tach in top gear. This looked like about 80mph indicated on the speedo, which I don't know the accuracy level of. I didn't have a GPS to check it.
So anyway, it seems like a good overall improvement to me.
Not a miracle, but some noticeable improvement over the previous K&N filter that I had in there. Nothing got worse, didn't seem to adversely affect anything in the Stage One PC-V map that is in my PC-V, so it should work fine with the map that you have in there working for you now.
I don't have any dyno testing, and this is just a subjective feel test.
I liked it.
It's not going to turn the bike into a raging racing bike, but it feels better and more free and relaxed to me, and a little more powerful.
So, that's a genuine and realistic impression of what it is in real life, compared to the same bike with a K&N in the stock airbox.
No hype.
I think most people would like it.
