As mentioned in a previous post, I reached out to the good folks at Amal about that idle screw issue, and here is their response along with my original inquiry/enquiry as promised:
Dear Mr Connelly,
The Monobloc Throttle Stops are also a 2BA thread and can be used. The stop would need shortening slightly. I've just tried this to prove it can be done and you'll need to find a shorter spring as the Monobloc spring becomes coil bound before it starts to move the throttle valve. I shortened the screw to approximately 36mm.
Kind Regards
Phil Beresford
Customer Services Advisor
Burlen Limited - The SU, AMAL & ZENITH Carburetter Companies
Spitfire House, Castle Road, Salisbury, Wiltshire. SP1 3SA
Tel: +44 (0)1722 412500
Fax: +44 (0)1722 334221
Email: customer.services@burlen.co.uk
Website:
http://www.burlen.co.uk-----Original Message-----
Sent: 15 July 2020 13:24
To: Sales Department <info@burlen.co.uk>
Subject: Throttle Stop Screw Spring for Premier Series Concentrics
E-mail: [xxx]
Telephone: [xxx]
Dear Amal:
Some users of your new harder-wearing Premier Series of Concentric have described how engine vibration can cause its now unsprung throttle stop screw to change position, thereby either increasing or decreasing engine speed. Would the throttle stop screw spring described at
http://amalcarb.co.uk/throttle-stop-screw-spring.html fit the Premium models and perhaps cure this? Alternatively, are the older style sprung throttle stop screws compatible with the new Premier models?
With Regards,
Bill Connelly
Woodbridge, Virginia USA
