Would the results be any different with the custom head and cams?
Not really, unless it also had a bigger throttle body or bigger carburetor. The 34mm stock throttle body would be a limiting factor. It also limits the 535, but not as severely. As a result, you reach approximately the same hp out of either one with a full out build, but different performance characteristics from each. The 535 just revs faster and higher, and makes its hp a bit higher in the rpm curve, while the stroker works at a bit lower rpm. I think the best Hitchcock 612 dyno figure shows about 1 hp higher than we have seen from the best 500/535 jobs over here, but it is almost within a margin of dyno error/variation.
Anyway, the comments about the behavior from the previous post are still accurate, IMO. It comes down to how you like your power delivery.
The long stroke generally also gives a bit more vibration, due to the faster piston speeds, all else being equal. If you have a bad vibrating 535, you might see some help with that from the nice quality Hitchcock crank. But if you have a smooth 535, you will likely notice more vibration from the 612.
My personal opinion is that you can do better with a 535, and if Hitchcocks makes a standard 90mm stroke version of that crank, like they do for the iron barrel engine, that would be a good foundation for the build. They make a very good crank, although a bit steep in price.
The experience from several of my iron barrel customers that built the 612 is similar, and at least 3 of them went so far as to take out the 612 crank and go back to the std 90mm crank from Hitchcocks, and were happier. Some of the others kept the 612 and liked it.
None of our all-out CGT 535 builds have had any problems with the stock bottom ends, although our sampling number is admittedly quite small for CGT.
I can't speak for GHG ,but I don't remember any reports of his UCE builds blowing out any stock bottom ends either.
