BW - Thanks for making that!
I have found that one of my main problems with the Albion is my shifting technique. I was trying to operate it like a Japanese gearbox, giving it a casual quick stab. None of that marvelous clockwork shifting wizardry appreciated that and rewarded me with lots of neutrals, everywhere.
The Albion technique that works best (i.e. more reliably) for me I found on an old REOC forum reprint of a 1940's magazine article:
1) Engage clutch.
2) Toe into selected gear and HOLD shift lever there.
3) Release clutch.
4) Release shift lever.
The stop plate positions the bellcrank. The bullet plunger has to lock into the detent to keep the bellcrank in position after you take your foot off the lever. Holding the shift lever in position against the stop gives the plunger time more to index, increasing your chances of actually engaging and staying in the desired gear.
As with all things Enfield, taking your time pays dividends. Of course, the corollary is that you may need to plan ahead a bit!
