The "gap" on this 1999 head &
similar era barrel was about 0.025", the gasket was around 0.040", so some crush. The alloy barrel was purchased probably 2004, and it was "NOS" then. Maybe that's why the numbers were relatively close.
I used the odd old "OEM" laminated copper/fiber/copper head gasket I had (142617) because it was a bit thinner than the newer premium "Cometic" brand composite gaskets. My old OEM head gaskets are different than the current H's stock which look improved. Around the pushrod tubes on this gasket I applied a thin ring of the Permatex "Grey" to attempt to ward off leakage there, one side being a bit concave. I also tried a fillet of Permatex aluminum anti-seize as a filler for outside the spigot on the theory that it might block carbon infiltration & later subsequent "bonding".
I have extra head gaskets if sealing becomes an issue. None of the head bolt recesses had the hardened washers inside when disassembled. Fortunately I had stockpiled a set from H's a while back. Even more luckily I suppose the head bolts hadn't swaged the soft head material around the studs...
When I go back in to retorque in a couple hundred miles I'll try the torque wrench, 15-20 pounds, whatever feels "snug enough". No reason to create a problem. It didn't seem to have a compression leak at basically "hand tight" levels, so there is apparently margin on the stock engine.
I'll keep an eye on the head gasket while I try to scrub in the new rings. Hopefully the factory recommended tight end gaps won't cause a problem. Lots of heat/cool cycles should do the trick, we'll see.
Thank you for all your support, I'll let you know of any failures or other issues arising from this build.
Best Regards - ACR -
