Author Topic: What did you do to your Royal Enfield today?  (Read 1855372 times)
0 Members and 14 Guests are viewing this topic.
Reply #5745 on: May 02, 2015, 04:42:03 pm
Gremlin - that looks good!  Can it be seen from the side at all, like the OEM unit?
Not so much.   maybe I'll add reflectors to the wheel spokes and sparkly tassels to the handlegrips ?
« Last Edit: May 02, 2015, 05:21:34 pm by gremlin »
Craig McClure
  • Riding over 50 years
  • "No Future In Getting Old"
Reply #5746 on: May 02, 2015, 04:53:10 pm
After 30,000km of regular riding over the space of 18 months, my OEM battery is finally failing - (at least I hope it's the battery and not the starter motor!)
Not a bad run for a stock battery though.
Installing the Motobatt MBTX14Au today.
Update: farrrk. It was those f%#*ing negative battery terminals again. Should've checked those before forking out for the new battery. I wanted to see how long the oem lasted.
At least your new AGM MOTOBATT will never puke ACID over your chrome or paint. You will be glad you switched.
Best Wishes, Craig McClure
krimp
Reply #5747 on: May 03, 2015, 02:13:53 am
Replaced the fuel line today. No more gasoline smell when starting in the morning.
Living in beautiful Colorado Springs, Co.
2014 Cream C5
decker
Reply #5748 on: May 03, 2015, 02:29:07 am
 :D got out for a nice long ride. Gnarly ran fine except for some backfiring on deceleration. That's new. Hoping that it might be just a fouled plug?
"Let us endeavor so to live that when we come to die even the undertaker will be sorry."
Honda cx 500 custom - stolen
Honda 450 twin - traded up
Honda 650 nighthawk - blown up
Honda Goldwing 77- restored/ traded up
Bmw F650gs - sold to buy
2013 RE G5 Deluxe- last bike?
bluesdaddy2
  • aka Ross
Reply #5749 on: May 04, 2015, 11:17:14 am
Finally got the EFI short bottle exhaust and Power Commander installed.  Like the sound of it.  Took it to work (30 miles one way) and it ran great, for the most part.  I did notice slight hic-up where it seemed like it missed fired.  Happened about six separate times, all spaced apart, with no load just a steady throttle.  Maybe a loose connect somewhere.  Anyone else experience this?
2012 Royal Enfield C5 Chrome/Black
1938 Harley-Davidson Model U (patiently waiting some TLC)
1975 HD Sportster (Gone but not forgotten)
Vergennes, VT
Ilion, NY
Reply #5750 on: May 04, 2015, 11:40:44 am
Seems like every time these bikes develop a "random misfire" it's a broken a negative battery terminal.  Not always, but a lot of times.  I'd start looking there as it is easy to check.
bluesdaddy2
  • aka Ross
Reply #5751 on: May 04, 2015, 11:50:25 am
That has crossed my mind and it will be the first thing I check.. Already been down that (hidden/broken connector) road once before but that time it just up and died on my son while I was out of town.  Didn't do much for winning him over to the RE camp.
Vergennes, VT
Ilion, NY
lemming
  • Weezin' the Ju-uice
Reply #5752 on: May 04, 2015, 03:39:15 pm
First commute of the year this morning...outstanding day for it! 60 deg. and crystal clear. Marvelous.
"I know you believe you understand what you think I said, but I am not sure you realize that what you heard is not what I meant"
2011 B5 Black - "Tonks" - My first bike. Gone, but fondly remembered.
2010 Harley Iron 883 1200 conversion - work in progress
1998 Yamaha YZF600R - streetfighter Mad Max
johno
  • 2012 B5 on the original Portland Dorset UK
Reply #5753 on: May 04, 2015, 05:00:37 pm
Not forgetting the sidestand cut out. vibration at speed can cause the thing to operate, cutting ignition for a split second. Happened on my B5 while overtaking, not nice! soon as I arrived at my destination the switch was disconnected....Not had a problem (fingers crossed) since.
2012 B5 Bullet
 K&N, sport muffler, 18tooth fr sprocket, Avon style fairing, 1958 pattern British army haversacks. Mitas tyres DiD chain. Carberry plate.
Reply #5754 on: May 04, 2015, 05:12:27 pm
Yes, the 'ol side stand switch.   ;)
bluesdaddy2
  • aka Ross
Reply #5755 on: May 04, 2015, 05:20:28 pm
That came out a looonnng time ago.
Vergennes, VT
Ilion, NY
Reply #5756 on: May 04, 2015, 07:03:16 pm
That's why I didn't think of it, I assume that's the first thing everyone does is unplug it.   ;)
Royal Stargazer
  • I have no idea what I'm doing.
Reply #5757 on: May 05, 2015, 03:00:35 am
I've been having some mysterious misfiring lately too. It would happen mostly at high speed (where it was most troubling) but nothing stopped it from also occurring on side streets. It was getting worse, too.
Decided to swap the BPR7ES plug out for the BPR6ES, administered a healthy dose of fuel injector cleaner, and checked some wires for the PCV as well as the battery cables. Nothing loose (or at least not anymore) and problem solved. Me and the bug that hitched a ride in my helmet just got back from a rather pleasant test ride.
2020 Royal Enfield Continental GT, A racer for more than just cafes
2005 Volvo S60 2.5T AWD, Two doors too many
2003 Royal Enfield Bullet, two-wheeled time machine
heloego
  • USA '12 C5, '06 ElectraX
Reply #5758 on: May 05, 2015, 03:18:32 am
Glad you're running ok, and the bug enjoyed the ride.  ;)
'12 C5 Classic
bluesdaddy2
  • aka Ross
Reply #5759 on: May 05, 2015, 11:08:24 am
Mine is still missing in a similar fashion.  I have also developed a problem that I never had before installing the new silencer and PCV, it backfires.  Not often and usually just one load pop.  Never had that before........
Do you know which of the actions you took eliminated the problem?  Spark plug, loose connection, injector cleaning?
Vergennes, VT
Ilion, NY
