Author Topic: What did you do to your Royal Enfield today?  (Read 1855560 times)
0 Members and 10 Guests are viewing this topic.
Rich Mintz
  • Daily rider in the city
Reply #5715 on: April 19, 2015, 06:23:26 am
I don't know if the lighter oil helped, since I also charged up the battery at the same time.
This is the bag:
http://www.amazon.com/Dowco-Rally-Pack-Value-Tail/dp/B001A6JH02
I have the same bag on one of my other bikes for months, and I've been very happy with it. It's a great compromise between value and versatility – and it's inexpensive enough that I don't really care that much if it gets stolen off the bike.
Rich Mintz - New York City
richmintz@richmintz.com
[/URL]
Reply #5716 on: April 19, 2015, 02:09:15 pm
Rich, that is a nice bag for the price.  Does it look like it could be mounted to the back of a cafe seat?  I may just stick with my backpack, but that bag does look like it is easy to install and remove.
Rich Mintz
Reply #5717 on: April 19, 2015, 02:41:49 pm
The bag has 4 D-rings, on the bottom on the 4 corners. So it can be mounted any way you like. It comes with various straps but you can bring your own too.
I have the 2 front D-rings hooked to the foot pegs, and the 2 rear ones connected by a double-ended strap that wraps under the pillion seat frame. The rear strap is just for stability (can be manually removed) because i didn't want to bother removing the pillions seat to attach it more securely.
[/URL]
johno
  • 2012 B5 on the original Portland Dorset UK
Reply #5718 on: April 19, 2015, 04:48:14 pm
Spent the afternoon de-rusting and painting away all the winter corrosion from my B5.
I also sorted the vagrant chain guard with a couple of washers between frame, guard and shock then fitted larger penny washers to the outer side of both rear shocks. feels more secure, just have to wait and see.
I fitted a small rear mudflap, the type with Royal Enfield in gold writing.
I removed the Givi panniers and catches from the pannier frames so I could finally fit my British Army '58 pattern haversacks as panniers, which I will keep on for the summer and use the Givi's for winter.
The bikes already for some summer trips and tours. Must remember to take a picture or two to share.....
2012 B5 Bullet
 K&N, sport muffler, 18tooth fr sprocket, Avon style fairing, 1958 pattern British army haversacks. Mitas tyres DiD chain. Carberry plate.
Carlsberg Wordsworth
Reply #5719 on: April 21, 2015, 10:21:53 pm
After re-installing the rear luggage rack last weekend and noticing from the top that it looks out of square I thought tonight I'd re-adjust. Well, even though it has slots I was unable to adjust it the way I wanted and ended up chipping a flake of the rear mudguard valance. Another battle scar.
Reply #5720 on: April 22, 2015, 12:30:47 am
Didn't do anything to the bike, but I'm getting ready to do some hydrographics to it.  I did a test dip with an old broken mirror today, and it came out descent.  I think there must have been very light oil left over in the storage tote that I'm using for a dip tank because I got some small bubbles in the main part.  Need to do a couple more practice dips, but I think it will go well.
Here is the pattern I will be using on the new cafe seat pan.  I will also be doing the primary cover in a carbon fiber graphic that should come out really cool.  :)
Scotty Brown
  • Scotty Brown
Reply #5721 on: April 22, 2015, 08:29:09 am
Took advantage of a nice day for a 189.5 mile ride once again without incident.
Reply #5722 on: April 22, 2015, 01:26:02 pm
...... I did a test dip with an old broken mirror today, and it came out descent........Here is the pattern I will be using on the new cafe seat pan......
Sick.  ;)  I like it  8)
Maybe you'd consider starting a hydrographic topic so we can all follow along and learn ?  Is it something that the average tinker could do ?
Reply #5723 on: April 22, 2015, 02:02:54 pm
I can definitely start a new thread.  In a sense, anyone can do it, but you do need tho know to how to paint as well.
heloego
  • USA '12 C5, '06 ElectraX
Reply #5724 on: April 24, 2015, 05:22:48 am
5K on the clock.
Changed Oil/Filter, cleaned her up and covered for the next week.
'12 C5 Classic
mc35803
Reply #5725 on: April 24, 2015, 11:47:53 am
Picked it up from the dealer Thursday,  rode 3 miles,  and put it on the trailer to take it home.  8)
Miles
The_Rigger
Reply #5726 on: April 24, 2015, 02:28:40 pm
Today I burned the mortgage, so to speak, on Fiona; just made the final bike loan payment (two years ahead of schedule) to the Credit Union... She is mine-all-MINE now.
(of course, being I'm back out on tour, I can't ride her...)
-Dave
2012 C5 Special
Reply #5727 on: April 24, 2015, 04:51:35 pm
Today I burned the mortgage, so to speak, on Fiona.....
 ;D ;D ;D
Reply #5728 on: April 28, 2015, 02:08:04 am
Started the finishing touches on the Blackhawk today.  :)
Magoo
Reply #5729 on: April 28, 2015, 03:37:22 am
After 30,000km of regular riding over the space of 18 months, my OEM battery is finally failing - (at least I hope it's the battery and not the starter motor!)
Not a bad run for a stock battery though.
Installing the Motobatt MBTX14Au today.
Update: farrrk. It was those f%#*ing negative battery terminals again. Should've checked those before forking out for the new battery. I wanted to see how long the oem lasted.
« Last Edit: April 28, 2015, 01:41:28 pm by Magoo »
