Spent some quality time with the Old Girl today; a couple of hours aimlessly putting around town, just for the sake of racking up saddle time... Got back to the house and decided to do something (*finally*!) about the tail lights & turn indicators...
I had picked up a set of bullet lights on 75mm stalks from Hitchcock's, last summer when I thought I'd have time to do anything (Ha!), and still had a set of four short-stalk bullets from NFG... The Hitchcock lights were just the ticket for the rear end; swapped them for the OEM lollipops, and figured out a mounting method for replacing the OEM tail/brake lamp with an old '50s vintage street rod tail lamp... I would conservatively say it looks 472.8485003% better.
For the front end, I tried putting one of the Hitchcock bullets on... I thought they'd work better, as they are two-wire sockets (hot & ground) vs. the NFG shorties, which are only hot-wire and depend on the mechanical connection to the bike for ground, which I don't tend to trust... And just as well I don't; the single wire lamps wouldn't work with the bike's turn signal circuitry. But the shorties look soooo much better on the OEM fork mounds than the 75mm long mounts...
So I did the logical thing: Pulled a pair of short-stem NFG bullets apart, pulled my remaining pair of long-stem Hitchcocks apart, and put the 2-wire Hitchcock lamp sockets into the short-stem NFG bullet fixtures. Et Voilá! I have lamps that look summa cum sexy, *and* work just as good as the OEM canoe paddles.
Tomorrow: I move my 1,500-lb. tour toolbox home from my theatre, and take a crack at swapping a nice wide tractor saddle for the OEM torture-device-that's-passed-off-as-a-seat.
