What did I do to my RE today?
I lubed the clutch cable. It didn't take long and on a UCE it's easy to do with a 6 or 8 inch adjustable wrench, a squirt can of oil and a little time.
Don't even have to loosen or readjust any nuts or settings.
For you people new to the RE UCE's, to loosen the cable, find the clutch lever on the top of the left hand engine side case.
Put your adjustable wrench with its side face resting on the boss on both sides of the lever and adjust it so it fits snugly on it.
Keeping the wrench flat against the top of the boss, turn the wrench about 1/8 turn counter-clockwise.
Holding things in this position, flip the sheet metal yoke that holds the end of the cable with your finger so the enlarged end of the cable will slide out of the yoke's slot.
Relax and remove the wrench.
At the hand grip end, pull the cable a bit out of the casquette and move it forward and outward so the inner cable is pointing in the same direction the motorcycle is pointed. It will now slide easily downward out of the handgrip.
Slide the little rubber seal away from the metal end of the cable and pump some oil into the open area where the inner cable enters the outer cable.
Sooner or later, some oil will start to drip out of the cable down at the engine.
To reassemble everything, just reverse all of the above directions. There is a plastic strip on the grip end of the cable that needs to be in place. It looks like a thin piece of black plastic and it goes between the cable end and the aluminum handgrip to provide lubrication. Make sure it didn't fall off while you were working.
No need to readjust anything but while your futzing with it, it's a good time to check the cable adjustment.
The grip should move about 1/8" to 3/16" before it starts to activate the clutch.
