Rode it again - 45℉ this afternoon. It's strange to ride by the lakes and ponds and see them still white and frozen.
I'm pretty sure my bike is still pinging - rode it for a stretch of gentle uphill at about 55mph (about 20 minutes into my ride), my little digital tach showing about 3100 rpm, and didn't it rattle for a good bit of the climb! If I roll on the throttle a bit, the bike won't really accelerate, but I can certainly increase the noise. And, it doesn't happen every time.
It's weird. Sometimes, it just won't accelerate on the hills, but it stays quiet. Other times, it pings. Is it odd that in similar conditions it would ping intermittently?
Could be bad gas.
But if it's pinging, do what Scottie says and get the revs up above the torque peak where the engine wants full advance and is less likely to ping. And/or roll off the throttle till it stops. Don't mess around with ping! It can kill the engine very quickly, and it wouldn't surprise me to find that is what killed that bike in Italy that has its own "serious damage" thread going.
Pinging on an uphill grade, below torque peak with a bigger throttle opening than usual, can cause that very kind of incident where the owner thinks everything is fine, and he's gently cruising, and all of a sudden the engine comes apart. The pinging overheats the piston, which then expands more than the clearance can withstand, and it seizes hard and snaps the con-rod and the broken end of the rod blows out the engine case.
This has been the demise of quite a few Iron Barrel engines.
We know that this hasn't been typically seen in UCE bikes, but that doesn't mean it's impossible, so we don't want to tempt fate with pinging.
