Author Topic: What did you do to your Royal Enfield today?  (Read 1855560 times)
0 Members and 9 Guests are viewing this topic.
Reply #855 on: August 18, 2011, 05:54:40 pm
Do you still have the OEM Bosch plug in there?
I've had the NGK in there since about 800 miles. It runs well, but it didn't really do much to tame the idle. I'm still working on finding that sweet spot, "The Fountain of Idyll" Or, as the mechanic sez, "Good Luck on that! That's just the way some of them are." Maybe I'm a bit more tenacious, but I haven't found any real improvement yet. And I've had some 3100 miles worth of fiddling. ???
Reply #856 on: August 18, 2011, 06:00:50 pm
Apparently I've been riding so long I've forgotten how to drive.  The car felt really funny to drive, and this is the only car I've owned for 15 years and 200k miles.
I have a '96 Mazda (Ford) pickup that I bought new. 28,000 on it. Pretty much have forgotten how to drive it. Trying to split lanes is a pain! ;)
olhogrider
  • Classic 350 Desert Sand
  • Blue Ridge Mountains of NC
Reply #857 on: August 18, 2011, 10:16:04 pm
Every now and then I get the urge to split lanes in my car! I could fit through there.
Desi Bike
Reply #858 on: August 18, 2011, 11:29:28 pm
I did catch myself leaning over in a turn in my minivan the other day.
میں نہیں چاہتا کہ ایک اچار
Reply #859 on: August 19, 2011, 12:24:50 am
Ever grab for the clutch on the steering wheel? :P
olhogrider
Reply #860 on: August 19, 2011, 12:59:35 am
I finally got the HID bulb into the Minda 7" headlight. Looks really cool but I think it will blind oncoming drivers! Is that a bad thing? It lights up the house in daylight! I'll try it tonight but I think it is going to be too much. I went for the yellow end of the scale. I can't stand those blue/white ones plus it wouldn't look antique enough.
Reply #861 on: August 19, 2011, 01:12:25 am
A British bike with any functioning headlight is obviously not an antique! ;)
Reply #862 on: August 19, 2011, 01:19:36 am
I'm betting a few squirts of Genuine Lucas Electrical Smoke will dim that overly bright headlight.  :D
Reply #863 on: August 19, 2011, 01:20:15 am
Heh, I've waved at a few motorcyclists from my car before.   :)
Reply #864 on: August 19, 2011, 01:49:36 am
Most definitely.
 When the crotch rocket and HD guys in my area with those mods blind me I pull over quickly before loosing sight of the white line.
 Can the mod be tweaked, tuned or adjusted to give a more usable projection  ?
Reply #865 on: August 19, 2011, 02:07:38 am
Sounds like one of the complaints by some folks over on Team-BPH who feel their headlights are totally useless except to light up tree branches as they pass under them.
I may be wrong but it seems like the top screw slot could be elongated or even cut thru towards the rear of the bike.  This could allow the headlight rim (and bulb) to be aimed downward.
Yes, the rim wouldn't butt up against the bead on the nacelle like it should but at least the oncoming traffic wouldn't be blinded and veer over into  your lane and hit you head on.
Reply #866 on: August 19, 2011, 02:22:06 am
A couple of small wedges of rubber or plastic between the headlight and outer chrome rim do the same thing with much less aesthetic ickiness.
greekxj
Reply #867 on: August 19, 2011, 04:28:34 am
Cleaned/lubed chain on my 07 iron barrel. While doing that i noitced my rear brake switch all messed up. The bolts vibed out in the toolbox housing and threw the whole switch assembly out of whack. I fixed that and all is well now ;D
olhogrider
Reply #868 on: August 19, 2011, 07:36:01 am
it is not just the angle. It is more like high and low are on at the same time. I will try to reposition the lamp inside the housing tomorrow. If I cover the bottom half of the lens with my hand the high beam goes away leaving a nice low beam. Cover the top and the treetops are lit.
GlennF
Reply #869 on: August 19, 2011, 08:17:22 am
Sounds like you need gen-u-ine WWII blackout headlamp covers ...
