I've got a lot of tools, including a variety of test lights and meters, but one area my collection was deficient in, was equipment suitable for measuring and testing modern EFI systems.
So recently, I added a Hantek 1008C, which is a modestly priced USB Oscilloscope.
http://hantek.com.cn/products/detail/13170For around $80, I received a slightly used 8 channel O-scope with modest specs. It proved very easy to download and install the software on an old Win 7 mini-desktop that I salvaged from the computer graveyard, and I added a $10 VGA monitor from a junk store. Because all the processing is done in the 1008C, a high performing computer isn't needed, it's basically there for the display and to eliminate all the switches and buttons that add cost to a conventional O-Scope. My Hantek came with various probes, including a capacitive probe that clamps direct to a high tension spark cable. What it didn't have was current probe, that lets you measure current without interposing an inline resistance to measure voltage across.
Hantek sells this current probe, and it has good reviews for a $58 item:
http://hantek.com.cn/products/detail/77This got me to thinking about alternatives for a DC current probe. I have a few "Clamp meters", that I use for working on house wiring and machines at work, but these are only for AC. Where an AC current meter can get away with a simple ferrite ring, measuring DC current requires Hall effect sensors and buffer circuits. Since I have no straightforward and easy way of measuring DC current, especially large ( >10 A) DC currents, I decided I should add a handheld meter that was capable of this task.
Be careful if you decide to shop for one of these DC current clamp meters, most have siblings that look identical, but without the Hall Effect sensor, which renders them cheaper, but able to measure only AC current with the clamp. But, because they can still measure DC voltage, the ad copy can be misleading. Shop carefully!
The Habotest HT-206D is about the cheapest Hall effect Clamp meter that I found, that inspired some amount of trust.
http://www.habo-test.com/sale-11356939-ht206d-ac-dc-digital-clamp-meter-current-voltage-resistance-continuity-ncv.htmlThis gadget will measure up to 600A of AC or DC current and do quite a few other tricks besides, and can be purchased for less than $40.
But for just a few dollars more, I found various meters made by UNI-T. Various of these meters have been reviewed by parties online, including electrical engineering types, and they all seem to be saying good things about the UNI-T meters.
The UT 204+ can measure up to 600A AC or DC and can also measure frequency and temperature. It comes with a thermocouple capable of measuring up to 1000 deg C.
https://www.uni-trend.com/html/product/NewProducts/UT200_NEW/UT204+.html600 A DC means one could directly measure current draw of a full sized car or truck starter. For motorcycle work, a considerably lower max. value should be fine, and a meter with a smaller physical size is more likely to be in my pack when I'm far from home.
I think I'm going with this UNI-T UT 210D.
https://www.uni-trend.com/html/product/General_Meters/digitalclampmeters/UT210_Series/UT210D.html600V DC or AC measurement, 200A DC or AC, Also measures Resistance, Temperature, and Frequency and even does Non-Contact AC voltage detection. Uses two AAA batteries instead of a 9V, and fits into my size XL palm. Should be a nice piece of kit!
What do you guys think? What do you use for diagnosing your moto electronics?
