Took the bike out today , rode about a mile pulled over check the spark plug , it was way to lean so went up 3 sizes on the main jet. Carried on riding pulling over every so often to check the plug ,Played around with the needle a bit and went up one more size on the main jet , it's close enough to run in so did a bit over 40 miles.
It goes good obversly I couldn't thrash it but I can tell it's got more go ,can't wait to get this running in business out the way.
Did a compression test when I got home it has 140 psi
The repair job on the muffler is amazing , a lot quieter and the sound is is awesome I can't believe H's sell those damn things with no packing in them , it doesn't make any sense, away its sorted now.
So the bike is back on the bench to have push rod adjustment and check the timing again and just a general look over . So far so good 👍
