Dunno. You have to use the Royal Enfield app to use tripper, which I think is a pain in the ass.
It's a little finicky as well. I haven't quite figured out how to make it behave appropriately. With other nav systems, I pick my route, tap navigate, lock my phone, stick it in my pocket, and I'm off.
With the RE app, if I do that it stops sending nav info to tripper. There's been a couple of times when I've stopped mid-ride to sort it out again. However, when it functioning as intended I like it quite a lot.
I'm sure these issues will be worked out eventually, just not quite yet. So if you already have a solution you like, I'd just stick with that.
