Author Topic: access to front sprocket  (Read 1622 times)
sjbiat
on: October 27, 2021, 06:25:45 pm
Does anyone know if taking off the RH crankcase cover requires disconnecting the (Cozy) sidecar?
Thanks so much,
Stephan
stephan
09 C5 with Cozy sidecar now
formerly
97 Motoguzzi
94/02 Ural
85 BMW R80
64 BMW R60/Hollandia/Steib
61 BMW R69/Watsonian
60 Pugeot
  • Global Moderator
Reply #1 on: October 27, 2021, 08:29:07 pm
It may be possible. It depends on which model you have. A quick glance should tell you. I see no need to remove all of the struts from any model though, just whatever is in the way
www.cyclesidecar.com
sjbiat
Reply #2 on: October 27, 2021, 08:38:29 pm
Thank you Kevin.  Its great the way you monitor this forum!
I have a C5.  Can you get one strut out without removing them all?  (I ask because the Haynes manual says you have to remove the foot peg.)
stephan
formerly
97 Motoguzzi
94/02 Ural
85 BMW R80
60 Pugeot
sjbiat
Reply #3 on: November 10, 2021, 01:34:26 pm
I can now answer this question myself.  Yes.  (I had the work done by a dealer; an extra hour of labor.)
stephan
formerly
97 Motoguzzi
94/02 Ural
85 BMW R80
60 Pugeot
